Swapping Isspro EV's for EV2's? - Ford Truck Enthusiasts Forums
Old 11-21-2012, 09:56 AM
Km1210's Avatar
Km1210 Km1210 is offline
Km1210 has a very good reputation on FTE.Km1210 has a very good reputation on FTE.Km1210 has a very good reputation on FTE.
Is it possible to just swap out my EV's and put in EV2's without having to rewire everything?
Old 11-21-2012, 11:00 AM
Shake-N-Bake's Avatar
Shake-N-Bake Shake-N-Bake is offline
Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.
Unfortunately not. My EV gauges were wired completely different than the EV2 style. For instance, the EV Transmission Temp gauge had some sort of converter box between the sensor and gauge...the EV2 did not. If I remember correctly, even the boost gauge was different with respect to how it was wired.
Old 11-21-2012, 11:12 AM
honeydew honeydew is offline
honeydew has a very good reputation on FTE.honeydew has a very good reputation on FTE.honeydew has a very good reputation on FTE.honeydew has a very good reputation on FTE.
Gotta rewire like Greg said. I switched from EV to EV2.
Old 11-21-2012, 12:01 PM
Km1210's Avatar
Ahh I see.
Eventually I'm gonna upgrade the turbo and other things so the 0-30 lbs boost gauge isn't gonna cut it. Gonna need a 0-40 lbs or even 0-60 lbs boost gauge.
So do you guys think it would be worth the switch? Are the EV2's easier to set up then the EV1's?
I feel like this is gonna be a lot more work than I thought it would be.
Old 11-21-2012, 12:05 PM
I kept the EV 40psi boost gauge and have it on a pod with three EV2s. The EV with its incandescent bulb is dimmer, not as vivid a green, and not quite as evenly lit as the EV2, but they are all dimmed down anyway via dimmer switch. I kept it because it worked fine and I prefer a mechanical boost gauge. I prefer the EV2 electronic gauges because they don't have the amplifier boxes.
Old 11-21-2012, 12:54 PM
Km1210's Avatar
Quote:
Only problem with mine is 0-30 instead of 40.
What exactly is the amplifier box for? Is it for all three of my gauges (pyro,trans,boost) or just one?
Would I basically have to replace all the sending unit hardware from the EV's to the EV2's?
Sorry for all the questions, I just want to understand all thats involved.
Old 11-21-2012, 01:18 PM
I'm not sure what the amp boxes are for exactly but the EV2 don't use them. Wires run straight from sensor to gauge. You'll have to replace the trans temp sender but that is easy. I reused the EGT probe from the EV. The EV2 boost sensor thread should be 1/8" npt.
Old 11-21-2012, 07:45 PM
GoCamping's Avatar
GoCamping GoCamping is offline
GoCamping is gaining momentum as a positive member of FTE.GoCamping is gaining momentum as a positive member of FTE.
It is technically a re-wire, but you can work around it. I recently had a problem with the amp box for my coolant gauge and ISSPRO gave me distributor cost on a complete EV2 kit as a replacement (out of warranty). Newer gauge and just a few dollars more so couldn't complain there.
When I got into the removal / reinstall I was a bit perturbed because I was going to have to do a bunch of work I wasn't anticipating. But in the end I recall there were more wires with EV1 than EV2 so I spliced here and there and used some of my old wiring (i.e. didn't have to fish anything). A little ghetto but it works and was faster.
So I suppose if you want a completely clean install, remove all the old and replace with new but you can shortcut it like me.
Now my trans temp is on the fritz and I think it's time to call ISSPRO again for another EV2... I like the newer gauges but I don't like the fact that I don't have a matched set anymore!
Old 11-22-2012, 09:57 AM
Km1210's Avatar
Ok I'm understanding now.
I guess when the time comes, I'll replace them. Not an issue right now.
So to sum it all up:
My current EGT probe will work with the EV2's? That would be good.
And my boost is installed on the MAP sensor line I believe. I would be able to use that for the EV2's as well?
Thanks for the responses so far guys.
Old 11-22-2012, 11:53 AM
Tugly's Avatar
Tugly Tugly is offline
I'm a cautionary tale.
Tugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputation
All the wires, connectors, and sensors came with my EV2s... no need to buy anything extra (other than the pod). It might be simpler to just replace the old stuff.
EV1 vs EV6 Injectors RZAR Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 1 08-11-2015 10:36 PM
Injectors RZAR 1987 - 1996 F150 & Larger F-Series Trucks 0 08-10-2015 11:58 AM
ISSPRO EV`s vs. Performax Josh88Ford 1999 - 2003 7.3L Power Stroke Diesel 7 02-21-2011 01:52 AM
Isspro EV1 vs EV2 renyren 1999 - 2003 7.3L Power Stroke Diesel 11 11-20-2009 03:44 AM
Pros & Cons of EV vs EV2 MustangMatt96GT 1994.5 - 1997 7.3L Power Stroke Diesel 10 10-14-2009 12:23 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
