Hi is it possible to lower a ford E350 i know its not a F350 but i have been told it has the same chassis F350.The rear has leaf springs the front are coil springs twin rear wheels.I would like to lower it is there any kits you can buy.Thanks Pete
The front coils can be cut or replaced. The rear suspension can be lowered with a smaller lift block, or in extreme cases you can move the axle over the leaf springs.
Also, any vehicle can be lowered, just let the air out of the tires.
why on earth would you want to lower a HD truck for? You ordered a dually E350 so it must have a box on the back? all your gonna do is cause it too have handling issues and tire rub when its loaded....
