Map sensor location.
Thank you I had a feeling because it had a MAF it wouldn't have a MAP. Just wanted to ask because I have had vehicles in the past that had both.
The reason I was looking for it was I have been running lean and pinging at part throttle, even after replacing all the broken vacuum lines. I'm certain there is still a vacuum leak somewhere.
Do the throttle body/intake gaskets ever leak as they get older?
Also should the EGR on my vehicle hold vacuum? whenever I hook up my vacuum pump it works (stalls the vehicle/drastically lowers idle speed) but it won't hold vacuum for more than 3 secs.
It seems to only ping once the engine is fully warm. It runs great until its warmed up, then it starts pinging like mad at part throttle.
Well I rechecked my egr valve and it actually does hold vacuum, I don't know how I messed that up *shrug*.
I also checked my initial timing which is supposed to be 10 and at a certain angle it looked 10 but another angle it looked to be about 12-13. so what angle should I be looking at it from? Sorry if that sounds dumb.
panici33
10-05-2010 07:35 PM
