check transmission..od light constant flashing
hello out there thanks for stopping in and giving me your input..i have a 2003 mountaineer v-6 awd drives pretty good but od light is always flashing even if ignition switch is open and truck not started..and check transmission on message display also..the only thing that i feel its really tight on turns as if it wants to lock up but once steerring gets straight it runs fine...im hopeing some one has some info to share that can help me with this issue...maybe a fuse relay or sensor...please help and thanks too all that can help..i know that a regular scanner cant pull codes i gots to go to transmission shop but chances are there gonna tell me its trans time....
i guess im gonna try the soleniod pack..i have been shopping and looks to run abt 250 new..now to study up on how to empty her out and refill process and to see how quarts im gonna use..i also read that the new soleniod has to soaked in trans fluid????thanks for the help and info guys..any pointers are appreciated
turbo930ss
13
05-17-2013 12:36 PM
kellymastin
02-17-2012 02:38 PM
