Inertia Switch
11-20-2012, 06:32 PM
on
Inertia Switch
i NEED HELP WITH THIS. I have a 88 f250 351efi I would like to know if i am to have power to both wires with the key on. As it stands right now i have no power.
Thanks
Al
11-20-2012, 06:47 PM
You should only get power for 1 second or so before the computer turns the FP relay off.
11-20-2012, 07:13 PM
on
Would this cause not getting power to FP? Trucks turns over will not fire.
11-20-2012, 08:03 PM
Will what cause it not to fire?
Have you done any basic tests yet? Does it have spark? Does it fire with starting fluid sprayed down the intake?
11-20-2012, 09:13 PM
on
will run on start fluid. fuel pump will start if you ground #6 on self help. power to yellow wire on FR. thanks
11-20-2012, 10:31 PM
If the fuel pumps run when you ground the self test connector, then there is no need to play with the inertia switch.
Does it start up and keep running if you ground the self test connector?
dazedandcofused
08-09-2021 09:25 AM
CooterJoe
General Automotive Discussion
07-31-2016 10:24 PM
robert_l_ross
08-01-2011 09:40 PM
Fiat Altered
1978 - 1996 Big Bronco
05-03-2009 10:04 AM
BlueAngel69
01-10-2004 01:19 PM
