2003 F 150 4x4 not engaging - Ford Truck Enthusiasts Forums
Old 11-20-2012, 12:24 PM
mt.dave mt.dave is offline
mt.dave is starting off with a positive reputation.
I have a 2003 F150 5.4liter 4x4 and when it is cold I can not get the 4x4 to engage. It is a manual shift for the transfer case not electronic. It shifts but does not activate the 4x4 when it is cold. The 4x4 does work when the temp is about 30 degrees or better. Any ideas where to start?
Old 11-20-2012, 12:32 PM
Bluegrass 7 Bluegrass 7 is offline
Bluegrass 7 has a good reputation on FTE.Bluegrass 7 has a good reputation on FTE.Bluegrass 7 has a good reputation on FTE.
Sounds like an adjustment issue.
A contact is just making when temp is high enough and opens from shrinkage as the temp drops.
Good luck.
1997 F150 4x4 won't engage when cold. BGreener 1997 - 2003 F150 2 01-14-2013 11:03 PM
05 F150 4x4 problem whightower 2004 - 2008 F150 4 09-16-2010 05:30 PM
2003 f150 4x4 not workiong Ryan82 1997 - 2003 F150 2 05-13-2010 04:14 PM
4x4 Not engaging - 2002 F-150 Czacha 1997 - 2003 F150 6 12-27-2009 04:19 PM
4x4 not engaging dantsg Offroad & 4x4 2 09-14-2009 12:15 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
