Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Super Duty & Heavy Duty
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Super Duty & Heavy Duty 1999 to current Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines SPONSORED BY:
  #1 (permalink)
Old 11-20-2012, 10:22 AM
DMHG DMHG is offline
Garage is empty, add now
DMHG is starting off with a positive reputation.
003 F350 7.3 ESOF problems
My truck stopped shifting into 4wd recently. The switch tests as good, I replaced the relays and tried an aftermaket Dorman shift motor I had access to. The Dorman part did not fit well, btw.
I can manually shift the transfer case with a 9/16 wrench, with some effort.
All the fuses are good, although I should recheck them after testing stuff.
I am consistently getting the P1828 code which refers to the clockwise shift motor coil. Which is a little odd to me because it is in 2wd which is all the way clockwise.
This is not a hub problem, this is an issue with the transfer case shiftig. Someone help me out before I fab up a cable shifter or start driving my chevy 2500 with the shift lever on the floor again.
Thank you!
  #2 (permalink)
Old 11-21-2012, 12:32 PM
basket1021 basket1021 is offline
basket1021 is starting off with a positive reputation.
The only thing I can think of is the plug on the transfer case motor. I had a similar issue with mine, I was able to move the plug around on the motor and it was able to kick it into gear. From what I understand it is not uncommon for the plug to fail based on its location on the truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
