Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1957 - 1960 F100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 11-20-2012, 09:54 AM
K9sicem K9sicem is offline
Garage is empty, add now
K9sicem is starting off with a positive reputation.
Clutch line
I forgot the most important part in my last post. Where can I find the hose that goes from the master clutch to the slave. I have check many parts catalogs and have not found one. It there a name other then clutch line that I am missing?
Scott
  #2 (permalink)
Old 11-20-2012, 10:08 AM
theodore/teddy's Avatar
theodore/teddy theodore/teddy is offline
theodore/teddy is gaining momentum as a positive member of FTE.
Scott; first off welcome to the orphanage!
If you have the old one you can take it to NAPA or some other parts dealer and find a close match. This hydraulic line has been discussed here before and at that time there was only 3 NOS line found and no one remakes a direct replacement. Some have replaced theirs with hard line adding a couple loops for flexibility.
Good luck in your quest.
__________________
1959 F250 4x4
Wally
  #3 (permalink)
Old 11-20-2012, 11:12 AM
NumberDummy's Avatar
NumberDummy NumberDummy is online now
Ford Parts Guru
2013 Ford Escape
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
B7TZ-7A512-A .. Tube-Clutch Master Cylinder to Slave Cylinder / 1957/60 F100/950 / Obsolete
ONE available NOS / OP: You want the source? Send me an email sylhall@aol.com
If I post the source here, tube will gone in a NY minute. And activate your P/M and email features.
__________________
Bill // Retired Ford Parts Manager // SoCal Chapter member // Part Number Research: 1928/2001 FoMoCo vehicles.
2013 Escape SE FWD 2.0L Eco-Boost.
  #4 (permalink)
Old 11-20-2012, 12:55 PM
Email sent.
  #5 (permalink)
Old 11-21-2012, 02:30 AM
Ford Parts Guru
2013 Ford Escape
Email received, responded to, source/phone number passed along.
__________________
  #6 (permalink)
Old 11-21-2012, 05:39 AM
rocdril's Avatar
rocdril rocdril is offline
rocdril has a great reputation on FTE.rocdril has a great reputation on FTE.rocdril has a great reputation on FTE.rocdril has a great reputation on FTE.
Bill, if thats the same one you sent me, it was never found. I spoke with the parts dept. several times. They showed it in the computer, but could not find it on any shelves.
__________________
One 7.3s, One 6.4, and Three 6.7s
2012 Raptor, way too fast.
Semper Fi
RAY
  #7 (permalink)
Old 11-21-2012, 06:40 AM
Ford Parts Guru
2013 Ford Escape
There were three available at one time, now there's only in AR / Dealers webpage updated 11/14/2012.
If this dealer couldn't find it, I wish you had let me know. I would have called, asked them to remove it from Ford Dealer Parts Locator System.
Several other members have contacted me, saying if OP didn't respond within a certain length of time, would I pass along the info.
__________________
  #8 (permalink)
Old 11-21-2012, 06:47 AM
rocdril's Avatar
Yes, thats the one. I guess I should have let you know, to be honest I have been hoping for a call. They said if they found it I would be notified.
__________________
Semper Fi
RAY
  #9 (permalink)
Old 11-21-2012, 10:37 AM
GB SISSON's Avatar
GB SISSON GB SISSON is offline
GB SISSON is gaining momentum as a positive member of FTE.GB SISSON is gaining momentum as a positive member of FTE.
I made mine from off the shelf NAPA brake lines and a Double female brake hose that they had to order. I think the hose was about 9" long. Looks pretty much like the original, works perfectly.
__________________
'92 F350 4x4 dual wheel service truck. 7.3 with headers and glass packs. 5 sp man tran. 255 85 16 Toyos. 110,000 miles. '59 F350 9' flareside new project, cummins 6at turbo diesel, sm 465 4 spd. 255 85 16s again, 37 ford 1 1/2 ton stake with 53 flathead V8. 65 toyota landcruiser fj 45 longbed pickup. 54 GMC 3/4 ton flatbed w/ cummins 6at, '68 BSA 441 Victor Special, bone stock, Antique tractors and one lung flywheel engines .....
  #10 (permalink)
Old 12-01-2012, 01:53 PM
vntgtrk's Avatar
vntgtrk vntgtrk is offline
vntgtrk is starting off with a positive reputation.
Do you have a local place that can make one? I'm in the same predicament. But I have a place nearby called , House of Hose that can make one, but I have an original for them to work with
  #11 (permalink)
Old 12-01-2012, 09:57 PM
chetspencer's Avatar
chetspencer chetspencer is offline
2005 Ford Excursion
chetspencer is starting off with a positive reputation.
I just bought parts from NAPA like Mr. Sisson above. Came out perfect. Better than original actually, as I can replace just the hose if it ever fails. I used DOT5 btw and it's working great.
__________________
Chet
1959 F100 4X4 Custom Cab Styleside
2003 F250 4X4 Extra Cab Short Bed
2005 Excursion limited 4X4 6.0L
  #12 (permalink)
Old 12-02-2012, 10:08 AM
vntgtrk's Avatar
Double female hose sounds like a winner. I may make a bracket on the firewall to mount the union.
  #13 (permalink)
Old 12-20-2012, 01:03 PM
crlydave's Avatar
crlydave crlydave is offline
1958 Ford F-100
My Garage
crlydave is starting off with a positive reputation.
clutch line
believe it or not i used a steel braided front brake line from a polaris atv,worked perfectly!
  #14 (permalink)
Old 12-20-2012, 02:17 PM
vntgtrk's Avatar
Quote:
ORLY? Any other particulars, like year, we need to know? If not I'm gonna git one raht now.
Something like this?
http://www.ebay.com/itm/2003-Polaris...23256a&vxp=mtr
  #15 (permalink)
Old 12-20-2012, 02:25 PM
I'm thinking those would be metric?
__________________
1959 F250 4x4
Wally
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
