You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
None of our body style trucks had dual tanks. It should be 12v, I think '56 was when they switched to 12v but not sure, I do that all of our trucks are 12v though.
__________________
Colin
'59 F-250 Styleside Longbed, 292, 4spd, Rockwell 5.83 dually running gear, custom NP205 overdrive.
"The truck's a Ford and the tractor's green"
Scott; Your 58 was 12v stock. I'm not aware of a factory frame mounted fuel tank for the style-side pickups. Many of us have put tanks between the frame rails either in addition to or in replacement of the stock cab mounted tank.
Good luck in your quest.
__________________
Looking for an in bed spare tire mount for styleside fridge bed.
1959 F250 4x4
Wally
1967: First year FoMoCo offered an auxillary fuel tank for F100/350's, used in conjunction with in-cab fuel tank.
Manually operated fuel tank selector valve on floor adjacent to the drivers side of the seat switched the tanks. Toggle switch below dash switched the dash fuel gauge from one tank to the other.
For many years, aftermarket companies offered single and saddle auxillary fuel tanks.
I must have a 67 or later bed on my truck. It looks factory. There are no tank selector valve or toggle tank switch in the cab. The more i discover and work on this truck the more it grows on me.
I doubt you have a later bed, it wouldn't match the 1957/60 cab lines, wouldn't fit properly as there would be a large gap between the cab and bed due to increased wheelbases over what was available 1957/60, but...
I'll betcha if you have an auxillary or saddle tanks, they're aftermarket, cuz there was no such thing available from FoMoCo back then.
__________________
Bill // Retired Ford Parts Manager // SoCal Chapter member // Part Number Research: 1928/2001 FoMoCo vehicles.
K9sicem (thats an interesting name do you handle working dogs?)
Sounds like the fuss is about the fuel door in the side of your bed?
If you want to use that fuel door, I would hit the junk yards with a tape measure and find a tank that fits between your frame rails. Thats what I did I found a 22 gal tank from a rodeo but the fill is on the other side. Seems like early bronco's filled on that side and would be about right.
__________________
1959 F250 4x4
Wally
"What's all the fuss about, if your truck doesn't have an auxillary tank?"
I'm just tying to learn as much as I can about this truck. I don't mean to be fussy. That was also my first try at posting a photo. I'll get it right next time.
I used to own a Kennel and I trained dogs for Police work. I got my dogs from all over the world. After 20 plus years I sold the kennel and now I work for the State of Iowa regulating the Casinos.
I don't have a kennel or a kennel license, but have 5 Basset Hounds.
Lovable, but hard to train, you don't own them, they own you. So...no one in their rightmind needs any!
__________________
Lovable counts for a lot.... My 9' flareside bed has a factory made hole on the drivers side. I always wondered why, but then I saw a '65 9' flareside .with a gas cap there. So now I know the bed I found came from a '65 or '66. Now you got ME thinking of an aux tank.... to fill that hole. A PO riveted a crude patch over it, but from the inside you can see it's a neat factory hole. With the recent fluxuations in fuel prices, it could be a money saver........
__________________
'92 F350 4x4 dual wheel service truck. 7.3 with headers and glass packs. 5 sp man tran. 255 85 16 Toyos. 110,000 miles. '59 F350 9' flareside new project, cummins 6at turbo diesel, sm 465 4 spd. 255 85 16s again, 37 ford 1 1/2 ton stake with 53 flathead V8. 65 toyota landcruiser fj 45 longbed pickup. 54 GMC 3/4 ton flatbed w/ cummins 6at, '68 BSA 441 Victor Special, bone stock, Antique tractors and one lung flywheel engines .....
I can almost feel the excitment here in the land of taxes! Hey by the way Gary, have you had enough rain lately or has all that stuff missed you?
