Offroad & 4x4
dana 70 front ????
Old 11-20-2012, 06:08 PM
alpha/omega's Avatar
alpha/omega
alpha/omega is offline
Paul, i have selective reading skills :flip:
You can put an e-brake on a 205 rear output yoke. Several companies sell kits.
If you need to change ratios i would highly suggest finding a later 85.5-92 kp 60 and upgrading to 35sp outers if you feel the need.
Old 11-20-2012, 08:11 PM
captain p4's Avatar
captain p4
captain p4 is offline
Though if the d70 is already setup to more or less bolt in and has what he needs.. might be better off matching the rear axle to it instead of trying to match the front to the rear for gear ratio. Depends on what the d70 has in it and how much gear he needs/what he does with the truck I guess.
Old 11-20-2012, 08:12 PM
CS79bronco's Avatar
CS79bronco
CS79bronco is offline
The 205 t-case will fit right on the ZF (it is 5spd?) in place of the parking brake. Or most any other t-case from Ford. Should be similar with auto. Someone advised me that there is some regulation that requires that parking brake unit on a service type vehicle such as F-Superduty when I was researching a ZF swap. That is a 4 x 4 trans if it has the parking brake on it, but used in 2 WD trucks.
Old 11-20-2012, 08:13 PM
mrblonde108's Avatar
mrblonde108
mrblonde108 is offline
I have a small 17 foot f450 rollback alum bed. i'd like to make it 4x4 so i can haul logs out of the woods to cut on my saw mill.
Old 11-20-2012, 08:23 PM
CS79bronco's Avatar
CS79bronco
Could your rear axle have parking brake capability, even if not used because of the drum on the trans? IIRC the drum was required for service trucks like with a hydraulic crane or man-lift, a separate brake from the hydraulic brake system.
Old 11-20-2012, 09:10 PM
mrblonde108
no to make it 4x4 i have to remove drum off tranny and in its place bolt on transfer case.
TC-Countryboy
12-27-2018 03:48 PM
79_250RangerLariat
01-05-2006 06:54 PM
fordmudrunner2020
Offroad & 4x4
09-16-2003 10:37 PM
sternal2000
07-30-2003 11:13 AM
i looove fords
02-23-2003 02:20 AM
Quick Reply: dana 70 front ????
