Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bio-diesel, Propane & Alternative Diesel Engine Fuels SPONSORED BY:
  #1 (permalink)
Old 11-19-2012, 05:21 PM
BoxedDuk BoxedDuk is offline
Garage is empty, add now
BoxedDuk is starting off with a positive reputation.
just getting started....
i just recently bought a 2001 E450 7.3L Super Duty Power Stroke V8 that i am going to run on wvo. i'm still researching but think i have a pretty good understanding of things. i'm going to basically run a 2 tank system similiar to the one joshua talks about in his book from the fryer to the fuel tank. what i'm curious about first is there anything i should know about my particular engine as far as replacing any factory parts before running the vo through the system (hoses, o-rings, etc.....) also, what? if any! possible benifits would having an electric engine block heater play in the conversion process...oh yea by the way i am going to do the converssion on my own without buying a kit i'm going to get as much as i can from the junk yard with the exception of new filters & hoses.....any enlighting input is welcome....still researching but very excited about conversion so i'm going to be getting started soon!!! very interested in dual 3 port solenoids for a closed and open return line so that it has a purge for air build up? any suggestions!?
  #2 (permalink)
Old 11-22-2012, 08:37 AM
Christof13T's Avatar
Christof13T Christof13T is online now
The Dr. will see you now.
2000 Ford F-350
My Garage
Christof13T is a splendid one to beholdChristof13T is a splendid one to beholdChristof13T is a splendid one to beholdChristof13T is a splendid one to beholdChristof13T is a splendid one to beholdChristof13T is a splendid one to behold
christof13t
first things first.
the condition of your oil is critical for the safe long term use of vo/wvo.
2nd poly or aluminum tank... check.
heating system... you have some options for this but most of the guys here like to use tube in hose heating with the engine coolant.
filtration before it ever goes in your truck! filter it down to at least 10micron before it goes in your truck! make sure there is no water in your oil... search hot pan test.
read, read, read.
when you think you have read enough... read some more.
big keys to remember.
clean oil.
no water in oil.
heat oil (at least 160*f)
purge oil out of heads before shutdown.
for purging you might want to think about one of the valve and circuit board kits on ebay that have a timing control board and 2 3way selonoid valves.
__________________
PAA#130-2000 F350 Lariat CC,LB,6x6 7.3DIT Block#1250671(Forged Rods), 4R100,4" Turbo-Back, $32.07 Turbo Replacement (thanx Dwayne), Bellowed Uppies, RiffRaff FRx&AIH Delete, Hutch/Harpoon,6637-MotorBug 406k & counting
1982 F150 XLT Lariat SCSB 4x4 (patiently awaiting her 4bt) Greast Beast
'06 Fusion SE v6 142k miles (hers) got a fresh motor at 74k - Doh!
AE Total Ford Enhanced Bundle
  #3 (permalink)
Old 11-22-2012, 04:34 PM
kirkharrod's Avatar
kirkharrod kirkharrod is offline
kirkharrod is gaining momentum as a positive member of FTE.kirkharrod is gaining momentum as a positive member of FTE.
Most importantly, can you find oil? WVO is in very short supply to us right now because the renderers are paying between $1.25 and $3.45 per gallon to the restaurants for used oil.
I recommend you collect at least 200 gallons and de-water and filter before you start a conversion. MaKe sure you and your family can deal with the mess, smell, spills, collection and storage of oil.
Like I always say:
Greasin'. It ain't for everyone.
__________________
2002 F-250 Super Cab, 289,000 miles, 89,000 on WVO; Greasecar conversion, 20 plate heat exchanger, AIH delete-water injection in its place, DIY stock fuel bowl delete, 6637 air filter w/ Pete's cover, Straight Piped, GPR LED mod, CAT ELC, 203* thermostat, Bosch auxiliary coolant pump, ext coolant filter, fumoto oil drain valve, Aeroforce Interceptor scan gauge, ISSPro trans temp, boost, EGT, elec fuel pressure gauges, Cyberdyne coolant, veg oil, ambient air temp gauges, 80W low beams/100W high beams. No major grease related problems.
  #4 (permalink)
Old 12-03-2012, 09:24 PM
7.3fan 7.3fan is offline
2000 Ford Excursion
7.3fan is starting off with a positive reputation.
7.3's make a nice SVO conversion
Ditto on the read, and then read some more. There's some real benefits to using a 7.3 to run SVO, and a couple different ways to do it.
My opinion is to look at the redundant (wvodesign like) two tank system: second tank, second fuel pump, second filter, check valve on stock fuel system. If something fails, you haven't touched your stock system (much). Don't even need a fancy three way solenoid valve!
Good luck! Not an easy project, but much reward!
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
