Bench to Bucket seat conversion
Howdy, <?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
I'm new to the forum and a proud owner of a 93 7.3L IDI. I would like to do a bench to bucket seat conversion on my truck. I have picked up some seats at a local u-pull-it they came out of a 95 extended cab & my tuck is a 4 door. The rails do not bolt up which I didn't expect them to but does anyone have any insight as to which year model would be easier to install without a lot of drilling and fabrication. Any help would be greatly appreciated. Thanks!
Aj
<o></o>
Aj
<o></o>
Received 3,102 Likes
on
on
on
You're gonna need more than a washer to brace this up. Ask me how I know. The bucket seat trucks have bracing underneath the floor that is spot welded in place. Also the outboard bolt holes, at least on my '91, were not the same, so I had to drill 4 holes per seat. The seat then proceeded to work it's way thru the floor so I had to add the bracing from a bucket seat truck.
It is kinda complicated but I will do my best to explain.
Only supercabs, Broncos and Lightnings had bucket seats.
You will need a seat pan from either a 40-20-40 seat that came from a reg cab or crew cab OR a seat pan from a lightning that had a 40-20-40 or buckets. Supercab and bronco is different , as you are finding out. You unbolt your supercab buckets from their brackets, then bolt the buckets to the seat pan. That will let you bolt it right into your truck
The seat pan is a bracket that the individual seats and console bolt to, then the seat pan bolts to the floor like a bench seat.
Doing it any other way is not going to be supported correctly
I'd do what Diesel Brad suggests about adding the whole floor pan. You can't believe the force that the mount bolts will see if you ever hit anything while strapped in with the seat belts. There is a reason Ford does what they do, rather than drilling four holes and putting some fender washers in for re-enforcement, But - do what you want, it;s your truck (and your ****!)
I'll assume yes, and continue...
Because of the above, these trucks are often found with bucket seats which slide forward when the back is tilted forward. As far as I can tell, the Bronco and Supercabs typically use the same bucket seats; it wouldn't surprise me to find that the floorpans are the same.
I have a bucket seats from a '93 Supercab in my '91 Standard cab. Only the outer-forward fastening location matched up so I had to drill 3 others. One of them hits an overlap seam, which is good from a strength perspective, but you need to be aware of that so you don't put a hole where you can't get a bolt through.
The challenge with this setup is that the seat sits a bit too high. I know I measured it before and documented it in here, but I want to say it's about 2" higher than the stock bench. I believe the floor pan on the Bronco/Supercab positions the seat lower (vs Standard cab), but I've not yet verified this.
I'm still searching for whether the best answer is in using a different seat or perhaps an earlier set of tracks which might position the seat lower.
