Aftermarket Cat question - Ford Truck Enthusiasts Forums
Old 11-19-2012, 09:52 AM
Hutch17's Avatar
Hutch17 Hutch17 is offline
Hutch17 is starting off with a positive reputation.
I bought an aftermarket Thunderbolt Hi flow cat. My question is will I have any problems with not connecting the tube thats on the existing stock one. The stock ones rusted to high heavens so I have to replace it.
Old 11-19-2012, 09:59 AM
Conanski's Avatar
Conanski Conanski is offline
Conanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud of
Aftermarket honeycomb cats don't need air injection to function correctly, and it's possible they may actually overheat and fail if you do connect it.
Old 11-19-2012, 02:38 PM
Hutch17's Avatar
So what should i do with the tube from the stock one? Just cut and forget?
Old 11-19-2012, 02:47 PM
Hutch17's Avatar
Theres two tubes going to the existing cat, is one a return or something? Also will it throw codes with out them hooked up?
Old 11-19-2012, 10:35 PM
Hutch17's Avatar
Any one ?
Old 11-19-2012, 10:42 PM
Nally427 Nally427 is offline
Nally427 is starting off with a positive reputation.
ive come across this same thing before, on my 5.0 i ditched all the cats and went with longtube headers. i had just cut the pipe leading to the first converter and i havent had any problems since. no check engine light, no problems running. but maybe put some sort of plug in it. but like i said i cut mine and ive had no issues with it
Old 11-19-2012, 10:52 PM
Conanski's Avatar
Quote:
Do you have a HD truck(F250 or larger)? You won't have any problems(codes) with just disconnecting the tubes except that they may produce some noise when air is being pumped through them.
Old 11-20-2012, 06:40 AM
Hutch17's Avatar
yea Its a 250 with the 351. Thanks for the help guys!
Old 11-21-2012, 10:28 AM
Roger T. Pipe's Avatar
Roger T. Pipe Roger T. Pipe is offline
Roger T. Pipe is starting off with a positive reputation.
Quote:
Sorry to hijack, but I'm replacing my cat this winter on my HD >8600 '96 F250. Is there a difference with the cats on these models? It has a 5.8 A/T 4x4. Any good cat recommendations for it? Thanks in advance!
Roger
Old 11-21-2012, 10:32 AM
Conanski's Avatar
No difference except that the cats are usually high capacity.
Old 11-21-2012, 03:15 PM
Hutch17's Avatar
My new cat got here today nice and shinny!
Old 12-08-2012, 09:38 PM
Hutch17's Avatar
Hey guys I got my exhaust all hooked up a couple weeks ago. One problem, it sounds like there is an exhaust leak. I think there's a small one rights infront of the cat, that's no problem. I think the two air injection tubes are producing the exhaust leak noise. I doubt I'll pass emissions with it like that. How would you guys recommend plugging the air injection ports that the engine? Or could I get away with just leaving them disconnected?
Old 12-11-2012, 07:53 AM
Hutch17's Avatar
Any one???
Old 12-11-2012, 11:26 AM
DPDISXR4Ti DPDISXR4Ti is offline
DPDISXR4Ti is gaining momentum as a positive member of FTE.
The best solution would be to remove everything and plug the fittings in the heads. I know on the 4.9 this is done with 9/16-18 x 2.5" bolts. If you leave in place the related electrical controls and cap off any vacuum lines you should not get a CEL.
Whether or not you will pass emissions test is a function of what state/county you live in. Technically, by removing emissions equipment you *should* fail a visual inspection, but the enforcement of this law is highly variable and subjective.
Old 12-11-2012, 12:57 PM
Bob Gervais's Avatar
Bob Gervais Bob Gervais is offline
Bob Gervais has a great reputation on FTE.Bob Gervais has a great reputation on FTE.Bob Gervais has a great reputation on FTE.Bob Gervais has a great reputation on FTE.Bob Gervais has a great reputation on FTE.
On the 351 they're 5/8-11 thread. I used 1" long bolts to plug mine.
headers and cats curtk69 2004 - 2008 F150 0 01-19-2013 02:55 PM
Straight pipe to MPRB comparison rbloodhound 6.0L Power Stroke Diesel 3 08-28-2007 07:30 PM
po420 econo666 1968-2013 Full Size Vans 2 10-30-2005 12:42 AM
98 F150 Catalytic Converter Question sosF150 Exhaust Systems 0 03-25-2005 01:24 AM
Factory Cat or Aftermarket jwlines Modular V10 (6.8l) 3 05-26-2003 05:35 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
