Potential newbie to 84 Bronco
So I'm trying to do some research on a vehicle I'm potentially gonna be getting. I am told the Vehicle is sn 84 model year Bronco. I have read that the vehicle came with several engine options. It has a V8. In 1984, what V8 engines were available in the Bronco.What rearend options and gear ratios were available?
Lastly what's up with the front diff on these...is it a Solid axle or an Independant front suspension?
I believe '84 was also the first year for the High Output 351, too.
Rear diff is either an 8.8" or a 9". If the access plate bolts are on the rear, it's an 8.8". If they're on the side of the driveshaft, it's a 9".
Gearing is either 3.00, 3.50, or 4.11 (9"), or 3.08, 3.55, or 4.10 (8.8")
As far as I know, the Broncos didn't come with 3.73s.
The front is a TTB (Twin Traction Beam) and is more or less a combination of both an independent suspension and a solid axle.
It offers much greater control on and off the road at the expense of articulation.
So i found out it has a build date of 9/83 to me that indicates an 83 model year...correct?
I have a VIN:
1FMBU15F9ELAXXXXX
What I'm getting so far is an 5.0 based on the VIN...am i reading it right?...my friend swears up and down the engine in it is a 351m/400...maybe the engine has been swapped how do I tell for sure what motor is in it?
I have a VIN:
1FMBU15F9ELAXXXXX
If the engine was swapped, the transmission was swapped as well. The Windsor engine family doesn't share transmission bolt patterns with the 351M/400. The 351C is merely a pre-smog era 351M. The simplest way to tell the 351M from the Windsor family engines is that the "Cleveland" family have eight (8) bolts per valve cover while the "Windsor" engines have only six (6).
I have a VIN:
1FMBU15F9ELAXXXXX
I have a VIN:
1FMBU15F9ELAXXXXX
And yes, VIN digit 8=F is a 5.0L engine, at least that was what it was built with.
I always thought those had a straight axle in it. Oh well, anywho unless someone swapped a 351M into it, it wouldn't have it. It is probably still the 5.0 motor, from what i have been told, if you see a door tag that says, for instance, 83 then the year of the vehicle is an 84 because that's when it was finally completed.
If images help, here is a 351M
It's a little fuzzy but the 9" rear end looks like this from the driveline side.
The back side looks like it is all one piece and there is no removable cover like there normally would be. the 8.8 has that cover.
There is evidence to support that a few of the early 1980 models actually made it off the line with the solid D44. Its been ages but we had someone actually post a build sheet from a 1980 unit that indicated the non-TTB axle. That is the only reason I mention that 1980 was a questionable cut-off point.
