SD valve cover gasket/harness
I need to replace my valve cover harness setup, one pigtail plug is melted and I suspect a bunch of the harness under the covers are cooked.
What has to be done to switch to the SD harness? From what I understand the wires are a heavier gauge? Just match up the wires from two pigtails into one?
Also, I need my replacement asap, so I have no use for this one, but want to share it with someone on here that might. 2 SD harnesses Ford OEM on Ebay. Cheap, cheap, $40.00 and ends tomorrow. Slow shipping is why I don't buy it.
http://www.ebay.com/itm/FORD-7-3-DIE...3253ef277#shId
Last edited by NWO_diesel_nut; 11-18-2012 at 09:08 PM. Reason: Add Ebay info and link
Well I got it 3/4 accomplished today. Just have to cut old pigtails and put in the new one in the morning.
Wasted a lot of time trying to figure out how to take that back bolt on the passenger cover off. 13mm on 3/8 drive works pretty well when you crawl halfway into the front end.
Surprising how fast it goes back together. I know I spent 3 hours taking it apart and less than an hour putting it back together (for the most part)
Something interesting I found on the Dorman kit that I put in. The wires extend right from the pins and are zip-tied back. No more inside clip that comes loose (the 25 cent mod). I was surprised, thinking I was going to have to grind down a quarter.
If it works, I would be surprised why more people don't switch to the SD harness. The pins are quite a bit bigger than the OBS.
Also, any major reason to put the vaccuum box back in it's original place? I figured I would stash it further towards the passenger fender somewhere and fasten with zip-ties. Keeps it out of the way for 'next time'.
Ok, so I got the connections done, but the truck won't start.
I used quick splices for the time being so I could test if the truck would start before making soldered connections. Could the quick splices be the problem?
I want to verify that I made the right connections. On the OBS plug, it should go:
GP
INJ
GR
INJ
GP
Correct?
On the SD Harness it should go:
GP
GP
INJ
INJ
GR
INJ
INJ
GP
GP
Correct?
GP
INJ
GR
INJ
GP
Correct?
GP
GP
INJ
INJ
GR
INJ
INJ
GP
GP
Correct?
No I moved the wrap and loom on the harness back and got enough wire to make the connections. I don't have the extra time to remove the harness. I guess I will remove the tape on the new connections and put in butt connectors.
I only used one of the OBS grounds for the SD ground, the other is just disconnected, could that be the issue?
GP
INJ
GR
INJ
GP
Correct?
GP
INJ
GR
INJ
GP
Correct?
This if from left side of the plug to the right side correct?
I realize this thread is a bit old, but I was wondering, do you have the color code for the dorman pigtails to stock wire harness?
Thanks! This is exactly what I was looking for! Now I know how to verify that my injector harness on the outside got wired right.
I had the wiring wrong. Somehow one ground was connected to a power wire, according to mechanic. Truck ran for 4 months before it fried the pigtails and IDM. He replaced the SD UVCG back to OBS. My little screw up left me stranded and had to be towed, so I don't mess around with that truck anymore. Just run it till it dies for good.
