The spark plug nightmare is over
Been dreading this for a long time but finally did it. Changed the plugs in my 06 5.4. Took it to my buddies yesterday and got started about 11:30 am. Finished up around 8:30 p.m. $13 a plug at advance but had a $20 coupon for anything over $100. $100 for spark plug removal tool at napa that i could have got for $60 on ebay, hindsight always 20 20, and $14 for cheap set of really long needle nose pliers. A real pain in the butt but still way cheaper than the $600 dealer wanted. I would suggest to anyone going to attempt it to buy the tool beforehand and if you dont need it sell it on ebay. 7 out of 8 broke, but the problem fixed and shes runnin great now
I was thinking when I saw The spark plug nightmare is over
That maybe you traded for a diesel. But then we have our own set of nightmare things.
I agree that Ford should of put some more thought into component access. The last Ford
I changed plugs on that way easy was a 1972 Maverick that my dad owned. Inline 6
very easy to reach the plugs after you get over then being stuck. He had gotten
the car used. I think my worst was the 2002 Ranger with the 4.0L That one required
a blood sacrifice on 2 plugs.
How much skin and blood did you leave behind?
Sean
Sean
Has anyone ever tried an air hammer or air ratchet to remove these plugs? Forgive my ignorance as I have not attempted to do this to my 08 5.4 yet (only 50K miles). Are the plugs a standard looking plug? What causes all the heart ache? Crappy thin wall plugs? Threads exposed in combustion chamber?? Corrosion do to galvanic reaction with steel in aluminum? Check column D all the above???<O</O
Reason I ask is our shop E250s that had the 300 straight six (late 90s) would give us trouble with the plugs. The threads stuck far enough into the combustion chamber that carbon would build up on them making removal almost impossible. We found the air hammer action easily removed them vs. a hand ratchet. Of course the air hammer was set low and you needed to finesse it. You couldn’t bulldog it or they would snap off or gall threads etc...Fun stuff<O</O
I’m thinking some Kroil or PB-Blaster overnight or over a few days with some thermal cycling and a gentile 3/8" air hammer or air ratchet would make easy work of this fearsome anxiety ridden (what should be a simple plug change) job? No? Obviously I have not looked at this on mine yet but I'm getting ready to.<O</O
So the hex that the socket grabs is not metal but porcelain??? Guess Ill go to parts store and hold one for a clearer view. Have to go get shocks anyway.
ungerp check the tech section the removal has been well documented with the removal tool. Also do a search many have posted. The reason I posted was to ask if pneumatics would better assist removal
Denny
Your 2008 may be fine, I'm thinking it was mid year 2008 when they got them fixed. Look to see if your COP's are brown or black...brown means it's the new style. If they're the old plugs you might want to change them sooner rather than later. Plenty of posts on here to read about it! More over in the 2004-08 F150 side as they have the same engine.
You should be fine w/ your 2003, you still have the older style plugs. The problem w/ that era was blowing the plugs out, not sticking. But I'm thinking that was fixed by 2003. Just be sure to torque them to spec. Only the 2005-08 3 valve motors have the problem w/ sticking.
