fuel pressure sensor? - Ford Truck Enthusiasts Forums
Old 11-18-2012, 01:35 PM
j_blueridge j_blueridge is offline
j_blueridge is starting off with a positive reputation.
About 10 days ago I got a Check Engine Light. I had the Advance Auto guy connect to the computer and it translated as Fuel Temperature Sensor. I've got a 5.4L Gas engine. On-line I read that it would be the same code for the fuel pressure sensor located on the fuel rail on top of the engine.
I swapped that out and I still have the engine light. What should I do next?
Thanks.
Old 11-18-2012, 03:33 PM
projectSHO89 projectSHO89 is online now
projectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant future
Reset the PCM. Lights don't always go out by themselves immediately even when the underlying cause is repaired. You have to reset it...
Identify your vehicle so we know what you have....
Post the EXACT fault code, not a description or interpretation of the code by some parts store guy....
Old 11-18-2012, 06:56 PM
Right! I'll reset the PCM. Thanks.
I was lucky you could give me that advice without me telling you I have a 2007 4x4 SCab.
08 6.4 0192 code low rail pressure sensor circut low power Farmeloj 6.4L Power Stroke Diesel 0 07-17-2016 11:31 AM
Fuel Pressure Sensor Mounting Submarine Docker 1999 - 2003 7.3L Power Stroke Diesel 6 05-21-2015 03:30 PM
I need a CNG FRPS fuel rail pressure sensor cvCNG Alternative Fuels, Hybrids & Mileage 0 09-10-2012 03:25 PM
engine loses power pete315 Explorer, Sport Trac, Mountaineer & Aviator 9 07-15-2010 03:11 PM
fuel tank pressure sensor efajeep 1997-2006 Expedition & Navigator 2 06-17-2009 06:52 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
