Dear God Hellwig - Ford Truck Enthusiasts Forums
Excursion - King of SUVs 2000 - 2005 Ford Excursion SPONSORED BY:
Dear God Hellwig
Old 11-18-2012, 12:44 PM
jspence105 jspence105 is offline
jspence105 has much to be proud ofjspence105 has much to be proud ofjspence105 has much to be proud ofjspence105 has much to be proud ofjspence105 has much to be proud ofjspence105 has much to be proud ofjspence105 has much to be proud ofjspence105 has much to be proud ofjspence105 has much to be proud ofjspence105 has much to be proud of
Dear God Hellwig
Struggling to install this freaking bar. I have never seen instructions so completely useless in my entire life. These make ikea instructions look amazing. thin washer heavy washer....shockingly good and detailed. I'm about ready to throw this thing in the trash at this point. I've had every washer on and off at least 5 times and am still no closer finishing. I have 4 nuts that I have no idea what to do with. A little diagram with some arrows and part numbers and this would be done.
Old 11-18-2012, 12:54 PM
GIGGER's Avatar
GIGGER GIGGER is online now
Posting Legend
GIGGER has a superb reputationGIGGER has a superb reputationGIGGER has a superb reputationGIGGER has a superb reputationGIGGER has a superb reputationGIGGER has a superb reputationGIGGER has a superb reputationGIGGER has a superb reputationGIGGER has a superb reputationGIGGER has a superb reputationGIGGER has a superb reputation
Did you google it for more online info John
Old 11-18-2012, 01:03 PM
I just get links to this site, and I see no mention on any extra parts anywhere here.
Old 11-18-2012, 01:10 PM
Nicmike's Avatar
Nicmike Nicmike is offline
Proud Sheepdog
Nicmike has a spectacular reputation.Nicmike has a spectacular reputation.Nicmike has a spectacular reputation.Nicmike has a spectacular reputation.Nicmike has a spectacular reputation.Nicmike has a spectacular reputation.Nicmike has a spectacular reputation.Nicmike has a spectacular reputation.Nicmike has a spectacular reputation.Nicmike has a spectacular reputation.Nicmike has a spectacular reputation.
Sounds like you need photos of an installed bar. Anybody out there have pictures they can post up of an installed hellwig? Or take some and post them?
Old 11-18-2012, 01:22 PM
Quote:
I'm just lost too many different parts with no indication where they go. I thought I had it, now not so much.
Old 11-18-2012, 02:06 PM
sammie0126's Avatar
sammie0126 sammie0126 is offline
sammie0126 has a superb reputationsammie0126 has a superb reputationsammie0126 has a superb reputationsammie0126 has a superb reputationsammie0126 has a superb reputationsammie0126 has a superb reputationsammie0126 has a superb reputationsammie0126 has a superb reputationsammie0126 has a superb reputationsammie0126 has a superb reputationsammie0126 has a superb reputation
Quote:
Here you go....
Old 11-18-2012, 02:10 PM
Nicmike's Avatar
Proud Sheepdog
Sammie, I tried to rep you for being an awesome woman, but I have to spread it around some Thanks for the pics, and now John can get that thing done!
Treker58 Treker58 is offline
Treker58 is gaining momentum as a positive member of FTE.Treker58 is gaining momentum as a positive member of FTE.
Are they the same directions that are linked from this site
Hellwig 7643 Rear Sway Bar 2000-2005 Ford Excursion 2wd 4wd | $208.95
Has the direction link in the spec's section
Old 11-18-2012, 02:11 PM
timf150's Avatar
timf150 timf150 is offline
timf150 has much to be proud oftimf150 has much to be proud oftimf150 has much to be proud oftimf150 has much to be proud oftimf150 has much to be proud oftimf150 has much to be proud oftimf150 has much to be proud oftimf150 has much to be proud oftimf150 has much to be proud oftimf150 has much to be proud of
Its been awhile since I put mine together but it didn't give me too much hassle.
I had heard from others about the instructions being worthless so right from the start I did not even use them. What I did was put out all the pieces and organized them by type and size. Then I made a guess as to which pieces should go with each area of install. For example if I had four washers of a specific size and thickness then I set those aside to be used with the end links to the sway bar.
Here is a picture of what my final setup looks like. I am not 100% that its correct but it works and has not fallen off. The only part I know is not correct on mine is the top part of the drivers side end link where you need to have the bolt going through the bracket for the brake line.
Tim M
Old 11-18-2012, 02:13 PM
sammie0126's Avatar
Welcome! So been there done that, came inside frustrated and got on FTE and someone helped me figure it out, before I hurt myself, broke something, or resorted to large volumes of alcohol! Just returning the favors.
Old 11-18-2012, 02:18 PM
GIGGER's Avatar
Posting Legend
I repped Sammie for you John.......
timf150's Avatar
I sent reps her way.
She is showing her X who is boss and giving us boy some great information and a just "get it done" attitude.
Tim M
Old 11-18-2012, 02:32 PM
All installed. Thanks so much sammie I wish I had posted when I first started to get annoyed I ended taking everything apart again and putting the parts where they seemed like they should go. I still have 4 nuts and 2 washers, but I'll call them extra parts.
This is what it looks like now.
Old 11-18-2012, 02:41 PM
GIGGER's Avatar
Posting Legend
Well done John, now you can relax & watch a race, lol
Old 11-18-2012, 02:43 PM
timf150's Avatar
Good job....
I had a few parts left over and I ended up doubling up on some of the nuts as I didn't seem to have enough locking nuts.
As I mentioned I didn't read the instructions and I messed up on the drivers side end link install.
The instructions say on step 6...
6. On the drivers side, remove the emergency brake cable bracket. Reattach it by threading the bracket through our
end link mounting hardware. Add an extra nut to this end link to mount the bracket. SEE PHOTO (3).
Add an extra nut seems weird but I think that is one of the confusing parts of the install and is probably not necessary.
Did you add that extra nut?
Tim M
Warn locking hubs install problem wrdabney 1999 to 2016 Super Duty 18 10-07-2016 04:29 PM
c6 transgo shift kit Mullholland_F100 FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 0 03-09-2014 11:43 PM
Universal Windshield Washer Kit Chea77F150 1973 - 1979 F-100 & Larger F-Series Trucks 14 12-21-2011 05:26 PM
Copper washers for 9 inch 60F100 Clutch, Transmission, Differential, Axle & Transfer Case 6 05-02-2009 10:22 AM
Missing Thrust Washer - Automatic Hub Conversion tchad07 1978 - 1996 Big Bronco 1 05-09-2007 10:36 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
