Heater Air Control Issues
Guys,
I have a 2003 E450 Cutaway w/7.3 turbo. The air controls are not working properly.
Set control to floor, fan runs, no airflow at floor, just front of dash outlets.
Set to Defrost, a little airflow from defrost vents but most from dash outlets.
Fan speed set to hi....you can hear it running hi but airflow does not match fan speed...flow seems restricted or diminished.
What have I got here??????......temp control works as it should.
Would like the air to flow in the desired direction at the desired speed.
Thanks for any help.
Jon
Jon
Check the heater directional water flow valve next to the ac box. Its a metal valve with your heater hoses on it. make sure the.vacuum hose is closing and opening.
Also check for leaks at the ***** on the back of the selector switch.
207charlie1369
1997 - 2003 F150
01-12-2014 09:50 PM
mighty ford
06-19-2007 03:58 PM
