1948 F1 Hood latch ?
Hey guys, the PO off my truck installed a hood pin with a c clip to hold the hood down. I would like to go back to a stock set up. but I can't anywhere that makes all the parts. As there are none of the org. on my truck now. So is there another way to set up a latch with out going to a tilt kit? That is close to org. but I also wanted to close the holes up at the front of the hood.
Thanks,
Todd
Thanks,
Todd
Todd, People here go out of their way to be helpful, but here's a clue, they aren't just sitting around waiting for someone to ask a question, we have lives outside the forum. You need to have a little patience, posting the same question twice won't get it answered any quicker, and it's considered rude. Even if it happens accidentally, delete one of them before it gets an answer. Having two identical threads going is confusing for everyone.
Have you checked with Classic Haulers www.classichaulers.com ? Even if they don't have the new parts in their catalog, give them a call, they sometimes have the parts used. If you can wait a few days for an answer, one of the members here may have a spare set in their parts stash. The drilled holes will need to be welded closed and metal finished. DON'T try to fill them with bondo or fiberglass it won't hold.
Now Ax, let's assume that Todd didn't intend to double post...just a little eager is all.
Todd - you're best plan would be to buy a hood from someone parting out a truck. Check / recheck Craig's List. You might also contact the fellow from this CL ad, he has been handling recovered parts from old Fords for a while - could have what you need.
ford f1 parts 1948, 1949, 1950, 1951, 1952
Good Luck
DW
Good Luck
DW
Todd, It looks like you started duplicate threads? See my answer at https://www.ford-trucks.com/forums/1203810-1948-f1-hood-latch.html#post12533300
if your not in a hurry i think i have about all but the trim. you can not buy the dummy handle anymore i had to send mine out to be rechromed and it wasn't cheap. but i do have extras. all in need of chrome or paint and i think i have all the under hood parts also but it may take me some time to dig it all up.
Todd,
I have the hood dowel/spring assembly (on the left) that will fit your truck. I bought it a while back thinking that I would need it but now I don't. PM me if you need it.
The dowel assembly on the right is to a '52 and as you can see it is significantly different.
Are you sure that the dowel assembly on the right in your picture is from a 52? I've never came across a cup and spring like that in any of the 52 hoods that I've torn apart. The only difference that I know of (and by checking the parts in the catalog) are the dowels between the 48-50 and 51-52 model years. Everything else, cups, nuts and spring, are the same.
