Gas and Brake pedal adjustment
Steering column can be moved toward driver?
I also think the proportions are all wrong. Pedals are too close and steering wheel too far away. I have adjustable pedals and it is pointless because you can't make the pedals further away from you, just closer. Ford uses long arm, short legged monkeys for test fits. Must have been a 6 Sigma cost reduction idea.
QwkTrip - Steering column can be moved toward driver?
TILT OR TILT/TELESCOPE STEERING COLUMN
To adjust the steering column:
1. Pull the lever down to unlock the steering column.
2. Adjust the steering wheel up or down.
3. If also equipped with the telescope feature, adjust the steering wheel in or out.
4. While holding the steering wheel in place, pull the lever up to its original position to lock the steering column. .....
Owner Manuals ««« -click-
» [ Choose Year ] » [ Choose Make ] » [ Choose Model ] »
... I have adjustable pedals and it is pointless because you can't make the pedals further away from you, just closer.
Exerpted from the 2011 F-150 owner's manual (starting at page # 110) .....
... Press and hold the front of the control to adjust the pedals away from you.
... Ford uses ... short legged monkeys for test fits.
-click- the pic'
Goth 150
< This space intentionally -blank- >
the gas pedal and brake pedal are on a swingarm and the whole attachment can be moved manually. by taking out some pins the whole assembly can be moved forward or backward. i was just wondering if anyone had any experience doing this? if not i will take it back to the dealership and get them to do it
I wouldn't move the brake pedal closer to the floor than the OEM setting. If you need a change for you particular abilities see a pro who specializes in fitting a rig up for special people. Then you have a guarantee it is done right. Maybe tip the back of the seat up slightly, or the front back some.
