Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1957 - 1960 F100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1957 - 1960 F100 & Larger F-Series Trucks Discuss the Box Style Ford Trucks SPONSORED BY:
  #1 (permalink)
Old 11-17-2012, 07:36 PM
mixup mixup is offline
Garage is empty, add now
mixup is starting off with a positive reputation.
Roof Seam
What do you use to fill in the seam around the back of the roof on a 60 F100
  #2 (permalink)
Old 11-17-2012, 08:38 PM
oldebrush's Avatar
oldebrush oldebrush is offline
oldebrush is starting off with a positive reputation.
Roof Seam
Well, Most bodymen would use a product like "3M Body Seam Sealer". It's flexible, paintable and comes both in a tube (like weatherstrip adhesive) or brushable from a quart can. May be available in pints too, but for what you are asking, the tube should be sufficient. I'll be using it on mine when ready.
Aloha
  #3 (permalink)
Old 11-17-2012, 08:49 PM
economan economan is offline
economan is starting off with a positive reputation.
A specific seam sealer is available @ any auto parts store that carries autobody supplies.
if you are not particularly a steady hand at operating a caulking gun, or don't have a power caulking gun available to you I recommend masking tape on both sides of the seam, apply the sealer and using a rag that is well soaked with solvent wipe over the freshly applied sealer to smooth it and help push in to the crack. Then proceed to remove the tape right away whilst everything is still wet so you dont get any ridges on the seam sealer.
Oh ya.... by the way make sure that the inside of the seam is nice & clean, free of rust and primed before applying the sealer. Finish over the sealer with whatever primer you are using and you are ready for your topcoat.
AAAAnnnnndddd.......
Don't forget to check how the factory seam sealer islookin' inside the drip rails, with it being over 50 yrs. old it's likely pretty dried & cracked, you probably should freshen this area up whilst you are at it. As well as the seam between your boxside & taillight panel if it's a styleside box.
Mikie near ottawa canada
58 M-100 panel & 64 Econoline p/u
  #4 (permalink)
Old 11-17-2012, 08:51 PM
Thanks, I have a couple of tubes of seam sealer from another project. I just thought it was going to run out because the sealer is not thick.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
