'93 5.8 interpreting engine diagnostic codes
Still tracing an intermittent fast idle so I checked engine codes per the Haynes manual. The KOEO test revealed a code sequence of 3-3--1--3-3. The KOER (is there another key position that keeps the engine running?) test revealed the following:
quick 4 flashes to confirm half cylinder count
34 count pause
1 flash
10 count pause
1 feeble flicker
~5 count pause
then a sequence of 5 2 8 6 3 2 5 3 8 6 3 2
One guess is the engine off test reveals code 33 (insufficient EGR flow or throttle position erratic output) twice with a flash in between. If this is a 2-digit system, the engine running codes are 52, 86, 32, 53, 86 again, 32 again. The Haynes manual doesn't list codes 52 or 86. If this is a 3-digit system, I don't understand the engine off codes, and the engine running codes are 528, 632, 538, 632 again. But the Haynes manual doesn't list code 528.
Can someone make sense of these code sequences?
I removed the battery a few days ago to work on the master cylinder. I assume this erased the codes so they are a reasonably fresh set.
Sixto
'93 E150 Chateau 5.8 185K miles
34 count pause
1 flash
10 count pause
1 feeble flicker
~5 count pause
Sixto
34 count pause
1 flash
10 count pause
1 feeble flicker
~5 count pause
Sixto
34 count pause
1 flash
10 count pause
1 feeble flicker
~5 count pause
Sixto
T est conditions C continuous memory code
I'll t ag on your thread awhile
Code 52 is a power steering pressure switch circut open.....Code 86 is a shift solenoid circut failure.......Check engine light codes for OBD1/OBD2 Vehicles
34 count pause
1 flash
10 count pause
1 feeble flicker
~5 count pause
Sixto
34 count pause
1 flash
10 count pause
1 feeble flicker
~5 count pause
Sixto
Your van should be an EEC-IV system and use 3 digit codes. During the KOER test, the mechanic is supposed to do certain things at certain times, like floor it for a second, cycle the OD switch, tap the brake pedal, turn the steering wheel. The codes are from not doing these things.
The codes are here http://www.troublecodes.net/Ford/ The KOEO is simpler. Have you double checked the KOEO codes? Disconnecting the battery will not erase the stored codes but will erase the KAM(keep alive memory) which when erased, the truck will have to relearn for about 10 miles.
<table border="1" width="87%" align="center"><tbody><tr><td>
</td> <td>
</td> <td>
System shows voltage at pin 10 (is A/C on ?) or pin 30 (PNP, CPP switch) - PNP
</td></tr></tbody></table><table border="1" width="87%" align="center"><tbody><tr><td>
</td> <td>
</td> <td>
E4OD - Transmission Control Switch (TCS) should be cycled once between engine ID and Goose test
</td> <td>
</td> <td>
System did not receive "goose" test - TESTS
</td></tr></tbody></table>Does the check engine light stay on? I've owned a '93 E350 5.8 since 1998 and it has had an intermittent high idle since I've owned it. I can usually get it to idle down by hitting the gas pedal quickly to the floor and quickly releasing it. When that didn't work I'd turn the engine off and restart it and that worked.
I am tagging along since I got same problem....and if I turn the engine off and right back on the idle goes down. Are you implying that you could never get yours fixed so you lived with it?
right, I put up with it. I don't think it ever had any codes from that issue and it didn't happen often. This van became a secondary work vehicle 9 years ago so it doesn't get a lot of use now. She has 240K miles and still runs really well.
djbeck88
17
02-02-2011 05:00 PM
