Overheating pulling a trailer?
The other day I had to pull a 24' enclosed trailer around 700 miles through some winding and hilly roads. Across west Texas, and then down through south Texas. Trailer was empty for the most part, but it is a big wind pusher. My temp gauge stayed around 2/3 the way up the safe range. When climbing hills, it would get scary close to the edge of the safe range. I did not run in OD, only 4th gear and worked the gears as necessary to negotiate the hills and keep the RPM's up. My truck seemed way underpowered at times, for the task at hand. Here is the scoop on the truck:
1995 F350 4x4 bone stock, never had a programer on it. 194,000 original miles on it. standard tranny, zf-5 i believe. normal factory sized tires, no jumbo mudders here.
Thinking about getting a programmer to pull trailers a little better? Would a programmer keep the heat down? Will they add power, without sacrificing the life of my engine? Are they worth the money? What is a good one to go with. I don't want to drag race! Just tow and trailer, and hopefully save on some fuel.
Thanks for any input fellas.
I think you need to flush your cooling system. When is the last time you changed the coolant? Have you kept up on the sca additive? Just checking. Then you need an egt gauge to watch the exhaust temps before you put a chip in. A custom chip is best for these trucks, not a programmer.
Your sending unit could be bad too, but I'd think you'd notice something all the time then.
Quite a few options for chips. PHP, TW, Beans, BTS, DP, etc. There are others too.
SCA additive is to keep the cylinder walls from cavitating. It is important to keep up with that. If I were you, I'd flush the coolant system, and go to napa or the like and get some fleetcharge/fleetguard coolant. It already has the sca additive in it. 4 gallons of antifreeze and some distilled water.
Texas Bob
11-25-2013 08:05 AM
_red rocket_
Conventional (Bumper Pull) Towing; Travel Trailers & Pop-ups
05-25-2010 01:15 PM
