Supercharged V10 Excursion - Page 9 - Ford Truck Enthusiasts Forums
  #121
Old 10-07-2013, 12:11 PM
garryk6's Avatar
garryk6 garryk6 is online now
garryk6 is a splendid one to beholdgarryk6 is a splendid one to beholdgarryk6 is a splendid one to beholdgarryk6 is a splendid one to beholdgarryk6 is a splendid one to beholdgarryk6 is a splendid one to beholdgarryk6 is a splendid one to behold
Quote:
Originally Posted by Tylus View Post
I like the DIY traction bar. only 1 or both sides?
These are "Land-Yot's" designed traction bars. they were the Gen IV weld-on version. He no longer makes them. If you search the Excursion portion of this site, you will see a Thread that I did on these bars, and what they look like disassembled so you could see how to make your own.
Hope this helps, and yes, they are on both sides of the truck.
Garry
  #122
Old 11-12-2013, 02:39 PM
garryk6's Avatar
Latest work to the 00 Ex...
New Front Diff-Cover
New Rear Diff Cover
My Rear was leaking, and was very black, so it was good to get this done before winter. Front didn't look too bad, but the cover was very rusted and scaled up, so the new cover really dressed things up!
Nice to have full coverage!
I think I need to to adjust this one, as it may be hanging a bit off kilter...
Hope you enjoyed!
Garry
  #123
Old 11-12-2013, 10:08 PM
Tylus's Avatar
Tylus Tylus is offline
Submarines Once....
Tylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputation
nice new shiny covers. I keep hoping to score a shiny new 08+ style cover. one day
Garry
do you have a link? I searched the entire FTE site using your username and cannot find the post
  #124
Old 11-12-2013, 10:31 PM
Stewart_H's Avatar
Stewart_H Stewart_H is online now
The Nekkid Super Mod
Stewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputation
Here ya go:
So I finally got the LandYots off my 05, so here they are!
This is the tubing back to the all-thread
This is the overall length from the aft side of the pivot tube. It is the length of the tube and allthread.
Front plate is 2.5" square with hole in center for all thread.
The side plates are slanted and angled with the longer edge at 5" and the shorter at 4 3/4" with the shortest radius at 4.5". The sides are also 2.5" tall. The radius and ubolts are for a 3.5" diameter axle tube. The tube sleeves for the ubolts are 1.5" long. The spread between the ubolts is 5".
The reinforcing plate is 2.5" at the front plate and about 4 1/4" at the rear towards the ubolts.
The rubber bushings are 2" diameter.
The all thread is 3/4"
Bottom of axle bracket.
Top of axle bracket.
Pivot bolts are 1/2" diameter and 6" long.
These are the plates that are welded to front spring bracket. Since I am going to 5" blocks on the new Ex, I'm going to make new longer pivot bolt plates.
Here is the "Slapper bar" that needs to be cut off when mounting LandYots.
Here is the pivot plates when welded to the Ex spring bracket.
Here is the LandYot mounted to the rear axle with F350 rear blocks.
Let me know if there are any other questions!
Garry in AK
Stewart
  #125
Old 11-12-2013, 11:07 PM
Tylus's Avatar
Submarines Once....
thanks Steward!
  #126
Old 11-12-2013, 11:15 PM
Stewart_H's Avatar
You are more than welcome, Tucker.
Stewart
  #127
Old 11-12-2013, 11:30 PM
Tylus's Avatar
Submarines Once....
I lol'd out loud just then
  #128
Old 11-12-2013, 11:48 PM
garryk6's Avatar
Thanks for having my back Stewart!
Tylus, let me know if you need any more info. With them on the supercharged Ex, it eliminated the Axle wrap I was having when you combine big horsepower with big rubber and with 4.30 gears and 5" blocks. And when driving over washboard gravel roads and potholes, it actually steers straight, and the loosy goosy feeling is all but eliminated.
How this helps!
Garry
  #129
Old 11-13-2013, 02:25 AM
kornfanjoe's Avatar
kornfanjoe kornfanjoe is offline
kornfanjoe has a brilliant futurekornfanjoe has a brilliant futurekornfanjoe has a brilliant futurekornfanjoe has a brilliant futurekornfanjoe has a brilliant futurekornfanjoe has a brilliant futurekornfanjoe has a brilliant futurekornfanjoe has a brilliant futurekornfanjoe has a brilliant futurekornfanjoe has a brilliant futurekornfanjoe has a brilliant future
those rods dont look very hard to make with some patience. i am curious as to why there are the rubber bushings to isolate the two halves when most are one solid piece. i would assume this would allow more acle wrap flex and twisting??
  #130
Old 11-13-2013, 02:29 AM
Tylus's Avatar
Submarines Once....
Quote:
it's almost an identical copy of the 84-96 F series front axle radius arms rear bushings. matter of fact, I wouldn't be surprised if that is what was used
that system works great to allow articulation, but keep the axle planted fore/aft.
  #131
Old 11-13-2013, 09:42 AM
Wilmax Wilmax is offline
Wilmax is gaining momentum as a positive member of FTE.
Somewhere on this thread I posted a way I would make them that would be much better than the Landyot ones. I even included part numbers and describion of parts I would use.
  #132
Old 11-13-2013, 09:49 AM
I'm sorry it was not in this thread I believe it was in one of the "WANDERING" threads.
V10 Supercharger Found rock2610d Modular V10 (6.8l) 1 07-16-2016 08:23 AM
v10 supercharger ford1386 WTB - Parts & other 0 09-15-2015 11:30 AM
1997 F150 3.8L turbo or supercharger neags Supercharger, Turbocharger, Nitrous Oxide & Water/Methanol Injection 2 08-24-2012 05:30 PM
4.6 supercharger? Masterc333 1997 - 2003 F150 11 06-28-2012 12:48 AM
Options to boost '02 V10's power? AltaEx Excursion - King of SUVs 42 03-29-2009 10:15 AM
Tags
6.8, excursion, f350, supercharged, supercharger, v10
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
