F150 trailer towing mirrors - Ford Truck Enthusiasts Forums
Old 11-17-2012, 03:27 PM
boss1982 boss1982 is offline
boss1982 is starting off with a positive reputation.
Does anyone know what additional hardware/switches are needed to convert my 2011 F150 standard mirrors to the telescoping trailer towing mirrors?
Old 11-18-2012, 03:34 AM
blueovelboy's Avatar
blueovelboy blueovelboy is offline
blueovelboy has a very good reputation on FTE.blueovelboy has a very good reputation on FTE.blueovelboy has a very good reputation on FTE.blueovelboy has a very good reputation on FTE.
are your mirrors now power adjust, do they have turn signal, are they heated?
all of the questions you need to be answered before someone can answerer your question!
if you have no power or anything its possible to just get the same in the tow mirrors
Old 11-18-2012, 11:05 AM
I have the power adjust, heated with turn signals.
Old 11-18-2012, 04:46 PM
longboxlover longboxlover is offline
longboxlover is starting off with a positive reputation.
I just did the exact same swap on my 2012 xlt. i had the paddles that were power adjust, heated, with turn signals standard on the xlt. i put on fords trailer tow mirrors and everything was swapped over no problems at all.the wiring harness also fit right in with no problems. the tow mirrors are heated have turn signals, puddle lamps, and power adjust. they will only telescope manually though, they are not the power scope mirrors that are available on some of the new 2013's. to my knowledge if thats what you are looking for, your truck will be missing the fold switch and some required wiring. ther is a video on you tube showing how to remove the door panels. is was very simple.
Old 11-18-2012, 05:43 PM
it will be just like mine then and all you need is a philips and a 10mm or was it 13mm socket. took all of 10 min per side!
Old 11-18-2012, 11:25 PM
TheStuffz's Avatar
TheStuffz TheStuffz is offline
TheStuffz is gaining momentum as a positive member of FTE.TheStuffz is gaining momentum as a positive member of FTE.
I have power aiming (not folding or telescoping), signal lights, heated & automatic dimming drivers side mirror...
has anyone found tow mirrors with the automatic dimming???
Old 11-19-2012, 01:24 AM
boucheath boucheath is offline
boucheath is starting off with a positive reputation.
Old 11-19-2012, 04:57 PM
mine that i got from a ford dealer DO NOT have dimming on the drivers mirror.
Old 11-19-2012, 07:51 PM
Quote:
no such thing! its all controlled buy the rear view mirror. if your towing and have a big camper it wouldn't see behind the camper to work. thats why no dimming tow mirrors are made!
Old 11-19-2012, 08:22 PM
QwkTrip's Avatar
QwkTrip QwkTrip is offline
QwkTrip is a splendid one to beholdQwkTrip is a splendid one to beholdQwkTrip is a splendid one to beholdQwkTrip is a splendid one to beholdQwkTrip is a splendid one to beholdQwkTrip is a splendid one to behold
I really wish the tow mirrors came with auto dimming on the large mirror portion. On a dark road at night the headlights from cars behind can really blind and glare in my eyes. I have to turn the big mirrors in at night and use only the wide angle mirror. Had to do the same thing with my Superduty. Not so bad in a city where there is more light all around. I rarely tow but love the towing mirrors for everyday driving!
Old 11-19-2012, 08:59 PM
budman325 budman325 is offline
budman325 is starting off with a positive reputation.
Quote:
Where did you get the tow mirrors??
Old 11-19-2012, 09:40 PM
i got mine on ebay from babb ford in michigan. they were 300 for the pair shipped. they were easy to deal with and went out of their way to help out cause one of the mirrors came with a piece of plastic broken off, i gave them a call and they shipped a new one out right away, all i had to do was send the other one back postage prepaid. i would recommend them all day. i just checked on ebay and they don't have any listed right now but there are several other mirrors listed. good luck
Old 11-20-2012, 10:23 PM
TheStuffz's Avatar
Quote:
Darn.. that is the big twist in the arm that is making me hmm and haw at upgrading them.. that and i want the lights on the front like SD's have!
Old 11-21-2012, 12:40 AM
i got mine just for the fact theres no blind spots.
i have seen the supper duties tow mirrors on f150s but don't know if they hooked up the lights? but i would guess so
Just bought a new 2013 Expedition Max, need help with TT Mirrors.. EPI-911 2007 - 2014 Expedition & Navigator 3 08-26-2014 01:44 PM
Max tow mirror to paddle mirror swap? Rob.D 2009 - 2014 F150 21 11-18-2012 03:46 AM
2012 F150 Super Crew- Power Fold Trailering Mirrors? rpbf150 2009 - 2014 F150 13 10-29-2012 03:09 PM
towing mirrors 08 exp. flyboy5111 2007 - 2014 Expedition & Navigator 5 06-15-2009 10:07 PM
09 F150 Platinum Mirror Conversion HELP doughboy00008 2009 - 2014 F150 4 05-19-2009 06:41 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
