tail light replacement 2008 F-150 - Ford Truck Enthusiasts Forums
Old 11-17-2012, 02:16 PM
JimG1098's Avatar
JimG1098 JimG1098 is offline
JimG1098 has a great reputation on FTE.JimG1098 has a great reputation on FTE.JimG1098 has a great reputation on FTE.JimG1098 has a great reputation on FTE.JimG1098 has a great reputation on FTE.
Hello everyone. I'm over from the 48-60 group. I have a 2008 F-150 and I have to change my tail light. How do you get the housing out. I removed 2 screws, but it feels like there is something else holding it tight. Peeked under the bed liner, but it does not appear to help in any way
Thanks, JimG 1098
Old 11-17-2012, 02:29 PM
JimG1098's Avatar
Never mind. Read the book, it explained proper procedure. Got the bulb out and am going to get a replacement.
JimG 1098
Old 11-17-2012, 07:39 PM
danorules's Avatar
danorules danorules is offline
danorules has a superb reputationdanorules has a superb reputationdanorules has a superb reputationdanorules has a superb reputationdanorules has a superb reputationdanorules has a superb reputationdanorules has a superb reputationdanorules has a superb reputationdanorules has a superb reputationdanorules has a superb reputationdanorules has a superb reputation
Glad we could help
Old 05-31-2013, 01:36 PM
Mike Leary Mike Leary is offline
Mike Leary is starting off with a positive reputation.
My book explains all bulbs except the tail light assembly. Any help?
Old 06-01-2013, 08:47 AM
danorules's Avatar
Remove the 2 screws on the side of the assembly, drop the tailgate to see. Then pull the light assembly out, there will be a bit of resistance but that is normal.
Old 06-01-2013, 11:54 AM
bigunit54's Avatar
bigunit54 bigunit54 is offline
bigunit54 is gaining momentum as a positive member of FTE.bigunit54 is gaining momentum as a positive member of FTE.
yeah I just changed one of mine for the 2nd time since I have owned my truck. This time there was a lot of resistance. I really had to pull hard. But yeah, remove the two screws and that is all that holds it.
Old 09-17-2013, 08:45 PM
stresssolutions stresssolutions is offline
stresssolutions is starting off with a positive reputation.
Does this generation use standard base bulbs, or do they use the flat plastic base bulbs like the mid 90's generation? thanks
JimG 1098 build of the 54 F-750 Fire Truck JimG1098 1948 - 1956 F1, F100 & Larger F-Series Trucks 222 01-04-2017 06:00 AM
Happy Memorial Day and thanks for serving JimG1098 1948 - 1956 F1, F100 & Larger F-Series Trucks 6 05-25-2015 08:48 PM
Door seal infomation JimG1098 1948 - 1956 F1, F100 & Larger F-Series Trucks 16 05-07-2015 07:06 PM
Missing key to spare tire lock JimG1098 1999 to 2016 Super Duty 15 10-28-2014 11:00 AM
Radio intermitant JimG1098 2004 - 2008 F150 0 12-24-2013 11:57 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
