Rough Country lift.. Whats your thoughts - Ford Truck Enthusiasts Forums
Old 11-16-2012, 06:40 PM
bassman94 bassman94 is offline
bassman94 is starting off with a positive reputation.
1995 f150 4x4 regular cab extended bed. I have the aluminum wheels that came stock on that truck i cant remember the exact deminsions. I want a 2.5 lift to 3 inch lift. Rough country has a 2.5 suspension lift and recomends 32x11.50's which i do beleive to fit my wheels. but do you beleive i could get 33's on there and/or which do you think would be better. and whats the word on rough country lifts? any help is much appreciated ill try and post a few pics of the truck as soon as i figure out how.
Old 11-16-2012, 09:13 PM
91f150302 91f150302 is offline
91f150302 is starting off with a positive reputation.
Rough Country lift are great lifts. I've helped put a few on at a buddy's shop on jeeps and a few trucks and they are pretty easy to install and they hold up great. I'm sure that 33x12.50s would fit fine. it all depends on wheel size and offset. also some people like the wheel wells to be mostly filled by the tires and other like more room in there. its all personal preference. putting 33s on the stock rims may be a little big but craigslist always has an abundance of rims for sale for pretty cheap. the only reason i suggest a wider rim is because with having a 11.50 or 12.50 on the stock rims, you may see funny tire wear. i would say 10 inch rims and 33x12.50s on the 2.5 inch rough country lift would be a great set up. i am looking into this set up for my truck this coming spring too
Old 11-17-2012, 02:13 AM
darknight's Avatar
darknight darknight is offline
darknight is starting off with a positive reputation.
I'm sure the 33"s would fit. I had a mid 80's silverado(I know different brand) 1/2 ton, fairly low riding 4x4, and 32x11.50r15's fit without rubbing.
Old 11-17-2012, 02:57 AM
khadma's Avatar
khadma khadma is offline
Carpenter Local 745
khadma has much to be proud ofkhadma has much to be proud ofkhadma has much to be proud ofkhadma has much to be proud ofkhadma has much to be proud ofkhadma has much to be proud ofkhadma has much to be proud ofkhadma has much to be proud ofkhadma has much to be proud of
I would suggest using a system with extended radius arms, there is no
Substitute, except SAS.
4 inch lift works/looks better 33s.
Old 11-17-2012, 09:17 AM
my94red4x4 my94red4x4 is offline
my94red4x4 is starting off with a positive reputation.
2.5 Rough Country Lift kit
Hello all. I'm new here but I was reading this post and I have a comment that may be helpful. I have a 94 regular cab with a 2.5 inch lift kit with 33 x 12.50 tires on stock rims. The only problem I have encountered is a little rubbing on the radius arms when turning real hard to the right or left. This would be taken care of by a set of aftermarket rims with a decent offset. Other than that the kit is awesome. The stance is good the clearance is good and it handles really good on the road. I drive my truck 60 miles a day one-way to work and the ride is great. I have ran murders and at's , I prefer the at tires due to the miles I drive on the highway but the murders look wicked. Thank you for reading. I have some pics I can send if you are interested.
Old 11-17-2012, 04:02 PM
sounds good, ya i really would hate to part with my aluminum wheels, they look factory still and to me they just look awsome. but one other question, once the kit is installed does it make any differecne leveling out the front any? or should i just go ahead and add a leveling kit to the front whil shes all apart?
Old 11-17-2012, 05:36 PM
With mine all I done was add a 1 inch block to the rear. Now I set level. One thing you will need to get that is not in the kit is adjustable camber bushings. Just go for the good ones, I got Moogs for mine
Old 11-17-2012, 09:21 PM
ItsAFord55's Avatar
ItsAFord55 ItsAFord55 is offline
ItsAFord55 is starting off with a positive reputation.
the lift will not level your truck out
How much to lift 1995 F-150? Leatherneck W5 1987 - 1996 F150 & Larger F-Series Trucks 9 11-22-2016 12:51 PM
85 f250 lift FordPower92 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 13 12-22-2011 09:51 PM
Suspension lift ManfredVonRichtofen 1978 - 1996 Big Bronco 21 11-22-2011 02:05 PM
BDS or ICON? TYZ78F150 Excursion - King of SUVs 8 06-05-2011 03:03 PM
Rough Country 5 inch lift kit? playboy4aday Excursion - King of SUVs 7 05-09-2010 01:40 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
