Dana 60 Torque specs - Ford Truck Enthusiasts Forums
Old 11-16-2012, 01:43 PM
genscripter's Avatar
genscripter genscripter is offline
genscripter is starting off with a positive reputation.
Does anyone know what the torque specs are for the fill plug on a Dana 60?
I found this on a different website:
Quote:
Torque Specs on Dana 60.
Ring-gear bolts- 110 (lb-ft)
Bearing-cap bolts- 85 (lb-ft)
Diffrential cover bolts- 35 (lb-ft)
Kingpin-to-end forging- 500-600 (lb-ft)
Knuckle-bearing cap bolts- 70-90 (lb-ft)
Steering arm to knuckle nuts- 70-90 (lb-ft)
FRONT wheel-bearing adjuster (inner)nut:
Step 1: To seat, torque nut to 50(lb-ft) while spinning hub.
Step 2: Back off, then torque to 35(lb-ft) for automatic hubs,or 50(lb-ft) for manual hubs.
Step 3: Back off 3/8-turn for automatic hubs, and just enough to free the bearing for manual hubs.
Front wheel bearing lock (outer) nut- 160 (lb-ft)
Spindle to knuckle nuts- 65 (lb-ft)
U-bolts to spring-plate nuts- 150 (lb-ft)
Wheel lugnuts- 120 (lb-ft)
Rear-axleshaft-bearing retainer nuts- 25-35 (lb-ft)
Rear axleshaft to full floating hub bolts- 115 (lb-ft)
REAR wheel-bearing adjuster (inner) nut:
Step 1: To seat, torque nut to 50 (lb-ft) while spinning hub.
Step 2: Back off, then torque to hand tight or 1 (lb-ft).
Rear wheel-bearing lock (outer) nut- 160 (lb-ft)
Hope these helps all you heavy duty Dana 60 guys
Old 11-16-2012, 07:50 PM
tecgod13 tecgod13 is offline
tecgod13 is gaining momentum as a positive member of FTE.tecgod13 is gaining momentum as a positive member of FTE.
Just enough to keep it from leaking.
It has no load on it, so doesn't matter.
Old 11-16-2012, 07:56 PM
Excellent. Thanks.
Differential Cover Bolts Skyhawk Greg 1994.5 - 1997 7.3L Power Stroke Diesel 15 02-16-2017 10:04 AM
F350 Lugnut torque? four-sixty-power 1973 - 1979 F-100 & Larger F-Series Trucks 3 04-29-2016 08:25 AM
F350 4wd - switch to 2" blocks parts number list 2civicrr 6.7L Power Stroke Diesel 0 09-17-2015 11:54 PM
Rear Axle U-bolt torque spec???? 2civicrr 6.7L Power Stroke Diesel 4 09-04-2015 09:47 AM
Torque for rear sway bar to axle mount for u-bolts 250andEX Excursion - King of SUVs 1 04-08-2015 07:19 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
