Help with O/D trans ID
Greetings! Here's pics of the trans I wish to ID
I got this trans cheap with the hopes of using it behind a 223 in my '59, but the input shaft is waaay different from the T98 that came with the engine.
But can you help me figure out what this is? Here's some #s. On the 9 bolt side cover: TAAA-7222-A. The center section in front of the tailshaft housing: R10E-8. Tailshaft housing: R10E-1A
WG DIV
Also on the tailshaft housing: K28-50
Front input shaft cover: 8A 7050
Any help will be greatly appreciated. Unless I can use the input shaft from the T98 I guess I can't use it. But knowing what it is will help me sell the dang thang
WG DIV
Kinda figured that. My guess is it has a 6 volt solenoid and I'd need to swap that out as well as get a different bellhousing and clutch.
Don't remember the actual dimensions, but the input shaft is almost an inch shorter than the T98 and diameter is about 1/2" smaller than the T98. Unless I could swap the input shaft with one from the T98 I don't see this as being practicable. I will be using this as a truck instead of a trailer queen.
As I recall, cars used something like 7/8" diameter inputs, usually with 23 splines, while trucks used 1-1/8" with 10 splines. But some cars had 10 splines, which looks to be the case here. As long as the length is OK, and the pilot bushing fits, all that's needed to change is to get a clutch disc the right diameter for the PP, and with the correct splines. These are from an old NumberDummy post:
B7A-7550-A .. 9 1/2" Clutch Disc-10 Splines / Ford Passenger Cars: 1949/51 226 I-6 / 1952/53 215 I-6 / 1954/57 223 I-6.
B8A-7550-A .. 9 1/2" Clutch Disc-23 Splines / Ford Passenger Cars: 1958/63 223 I-6.
B8A-7550-B .. 9 1/2" H/D Clutch Disc-23 Splines / Ford Passenger Cars: 1958/63 223 I-6.
1957/64 Passenger Cars w/223's were also available w/a 11" 10 splined disc, 11" pressure plate.
This whole trans/OD unit was used into the '60's. My dad had a '67 Country Squire with it.
I would say it is more likely to have a 12v solenoid; check the cover on it. It is usually stamped with either "6v" or "12v"
Unfortunately the clutch linkage on '57-60 Ford trucks is hydraulic.
Another part # from the end of the solenoid: 1119772 made by Delco Remy.
Just thought of something: The truck had been modded to use a Z bar clutch linkage. I still have the modded pedal assy and would just have to remove the patch in the firewall.
jason832
09-19-2018 03:07 PM
pineconeford
06-10-2017 10:52 AM
mOROTBREATH
02-01-2010 11:41 AM
