Help with O/D trans ID - Ford Truck Enthusiasts Forums
Old 11-16-2012, 11:47 AM
vntgtrk's Avatar
vntgtrk vntgtrk is offline
vntgtrk is starting off with a positive reputation.
Greetings! Here's pics of the trans I wish to ID
I got this trans cheap with the hopes of using it behind a 223 in my '59, but the input shaft is waaay different from the T98 that came with the engine.
But can you help me figure out what this is? Here's some #s. On the 9 bolt side cover: TAAA-7222-A. The center section in front of the tailshaft housing: R10E-8. Tailshaft housing: R10E-1A
WG DIV
Also on the tailshaft housing: K28-50
Front input shaft cover: 8A 7050
Any help will be greatly appreciated. Unless I can use the input shaft from the T98 I guess I can't use it. But knowing what it is will help me sell the dang thang
Old 11-16-2012, 12:18 PM
ALBUQ F-1's Avatar
ALBUQ F-1 ALBUQ F-1 is offline
postin' fool
ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.
Car trannies had smaller diameter input splines, and it looks like that's what you've got. The R10 is what was used on cars and light trucks, R11 was heavier duty.
Old 11-16-2012, 12:23 PM
vntgtrk's Avatar
Quote:
Kinda figured that. My guess is it has a 6 volt solenoid and I'd need to swap that out as well as get a different bellhousing and clutch.
Old 11-16-2012, 12:40 PM
4tl8ford's Avatar
4tl8ford 4tl8ford is offline
4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold
What is the difference in the input shaft - Length? - Diameter?
Old 11-16-2012, 12:48 PM
vntgtrk's Avatar
Don't remember the actual dimensions, but the input shaft is almost an inch shorter than the T98 and diameter is about 1/2" smaller than the T98. Unless I could swap the input shaft with one from the T98 I don't see this as being practicable. I will be using this as a truck instead of a trailer queen.
Old 11-16-2012, 12:53 PM
ALBUQ F-1's Avatar
postin' fool
Quote:
As I recall, cars used something like 7/8" diameter inputs, usually with 23 splines, while trucks used 1-1/8" with 10 splines. But some cars had 10 splines, which looks to be the case here. As long as the length is OK, and the pilot bushing fits, all that's needed to change is to get a clutch disc the right diameter for the PP, and with the correct splines. These are from an old NumberDummy post:
B7A-7550-A .. 9 1/2" Clutch Disc-10 Splines / Ford Passenger Cars: 1949/51 226 I-6 / 1952/53 215 I-6 / 1954/57 223 I-6.
B8A-7550-A .. 9 1/2" Clutch Disc-23 Splines / Ford Passenger Cars: 1958/63 223 I-6.
B8A-7550-B .. 9 1/2" H/D Clutch Disc-23 Splines / Ford Passenger Cars: 1958/63 223 I-6.
1957/64 Passenger Cars w/223's were also available w/a 11" 10 splined disc, 11" pressure plate.
This whole trans/OD unit was used into the '60's. My dad had a '67 Country Squire with it.
I would say it is more likely to have a 12v solenoid; check the cover on it. It is usually stamped with either "6v" or "12v"
Old 11-16-2012, 01:19 PM
vntgtrk's Avatar
Here's some dimensions. T98: Input shaft is 6&5/16", tip to end of release bearing sleeve =3", 10 spline @ 1&11/16".
T85:shaft is 5" tip to end release bearing sleeve. 10 spline @1" D.
They share the D of the release bearing sleeve @ 1&3/4" and size of pilot bearing @ 3/8" ID
Old 11-16-2012, 02:10 PM
ALBUQ F-1's Avatar
postin' fool
So I think you'd need the corresponding bellhousing to make this work. Probably from a car. If the clutch actuates the same way, you could be home free.
Old 11-16-2012, 02:45 PM
tinman52's Avatar
tinman52 tinman52 is offline
Welder User
tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.
Yes, it will work with a car bell housing and the correct clutch. Clutch linkage should bolt up. 223 Car bell housings are are not as easy to find as truck ones as they are also used for T-5 swaps, but they are out there.
Old 11-16-2012, 03:22 PM
vntgtrk's Avatar
Unfortunately the clutch linkage on '57-60 Ford trucks is hydraulic.
Another part # from the end of the solenoid: 1119772 made by Delco Remy.
Just thought of something: The truck had been modded to use a Z bar clutch linkage. I still have the modded pedal assy and would just have to remove the patch in the firewall.
Old 11-16-2012, 04:08 PM
jim collins jim collins is offline
jim collins has a good reputation on FTE.jim collins has a good reputation on FTE.jim collins has a good reputation on FTE.
It looks a lot like the one in my 56 ford fairlane. They were 12 volt and i believe 10 spline. Passenger car housings place the trany about 1/4 to 3/8 " closer to the engine. I have one of each and that's what i found ,plus the truck hydro. clutch linkage .
Old 11-16-2012, 05:15 PM
vntgtrk's Avatar
Lotsa help from y'all. Thanks! Now I don't know if I should try and find a car bellhousing, sell the trans or find a late '50's Ford car that needs a trans. This one does need at least a bearing on the input shaft and one on the output shaft as well.
HOLY SCORE, BATMAN!! vntgtrk 1957 - 1960 F100 & Larger F-Series Trucks 49 03-16-2014 06:42 PM
Dual Snorkel Air Cleaner vntgtrk 1957 - 1960 F100 & Larger F-Series Trucks 10 02-16-2014 02:05 PM
Alternator conversion? vntgtrk Y-Block V8 (239, 272, 292, 312, 317, 341, 368) 10 12-18-2013 07:30 PM
75 f250 supercab 12v cummins finally outta the garage pruitt 1973 - 1979 F-100 & Larger F-Series Trucks 34 04-26-2013 08:08 PM
My 2006 Ford Ranger 4x4 (56k no way) dixie_boysles Ranger & B-Series 2 04-03-2010 03:26 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
