EGR Delete?
Old 11-15-2012, 09:32 AM
BFlemsr's Avatar
BFlemsr
BFlemsr is offline
EGR Delete?
Is there a distinct advantage to doing the EGR delete? Also, I see there is an EGR cooler delete kit? Shouldn't this cooler be there?
I guess what Im asking is should I do the EGR cooler and EGR valve deletes while I already have the Turbo off waiting for a new one? What are the advantages, if any, of doing the deletes?
Sorry for the bonehead questions but these Diesels are a whole new animal to me. This is all so confusing.. Forgot to mention this is on an '04 F250 Super Duty with the 6.0..
Old 11-15-2012, 06:17 PM
cheezit's Avatar
cheezit
cheezit is offline
not tring to sound rude but this has been beaten to death. the search function will pay off for all the info you could want on this subject
Old 11-15-2012, 08:00 PM
olfordsnstone's Avatar
olfordsnstone
olfordsnstone is offline
If it means anything to you, the guy that responded above is one of the Super-Diesel Gurus here on FTE. If you look at his signature you'll see he has the delete... That may be a significant hint to the value of a delete.
Anyway, yup there are a whole lot of discussions that have occurred on this subject and a search will give you plenty of reading for quite some time. One thing to remember, if you do the delete:
It is recommended to leave the egr in place and plugged in for proper fan operation for proper engine cooling.
Use the egr cooler bi-pass for the egr cooler and block off egr ports (you can leave the cooler in place but coolant bipassed so the cooler can be seen at a visual inspection.
Make sure to block off exhaust flow prior to egr valve so no exhaust gasses pass back into the intake of your engine. They will not be cooled with the egr cooler bipassed.
And finally, you will more than likely need a tuner to turn off the check engine light for low egr flow when it has become non-operational. SCT would be my choice.
Oh, and also if you do the delete you need to accept the risk. If you get caught, you are breaking the law and could be fined.
Old 11-15-2012, 08:25 PM
Curt's05's Avatar
Curt's05
Curt's05 is offline
Wiser by FTE
I didn't want sooty exhaust directed back into My engine! Elimate the need to clean/replace that valve in the future. My engine runs better, so 3 great reasons for the delete. Depending if your state has emmision testing "breaking the law may have consequences"
Old 11-15-2012, 08:48 PM
cheezit's Avatar
cheezit
cheezit is offline
hate to say but next time my intake is off i maybe installing a cooler again.
Old 11-15-2012, 09:02 PM
robert421960's Avatar
robert421960
robert421960 is offline
please tell us why?
Old 11-15-2012, 09:32 PM
PattonC222's Avatar
PattonC222
PattonC222 is offline
The suspense is killing me..
Old 11-16-2012, 12:15 AM
Bullitt390's Avatar
Bullitt390
Bullitt390 is offline
Certified Thread Hijacker
Might be because of emissions?
Josh
Old 11-16-2012, 12:17 AM
John Irwin's Avatar
John Irwin
John Irwin is offline
Ok, finally have internet in my shop....
The only guy grumpier than me is Moe...Cheezit, and he is also number one when it comes to info...
A delete costs the same as a bulletproof cooler.
I replaced my egr valve 2 years ago, and I've been using a cetane additive since then, and I've had no problems and don't expect any. I've heard about the 5 mpg increases with the delete and don't believe it.
We have had a right wing gov't for 40 years where I live, but the libs are taking over...I want to be able to pass the smog check when it comes.
Old 11-16-2012, 05:18 AM
Curt's05's Avatar
Curt's05
Curt's05 is offline
Wiser by FTE
I may have seen a slight increase in mpg, with clean combustion air it should go up.
You could do a poll to get members insight into your delete.
Old 11-16-2012, 07:06 AM
BFlemsr's Avatar
BFlemsr
BFlemsr is offline
Emissions is not an issue here since I live in NJ and we dont have to get diesels inspected anymore.
Old 11-16-2012, 05:41 PM
cheezit's Avatar
cheezit
cheezit is offline
i would like to be able to run stock. my mpg was also better stock. and yes because the bpd cooler is the same cost as oem.
Old 11-16-2012, 05:50 PM
Bullitt390's Avatar
Bullitt390
What PCM/ FICM strategies are you running?
Josh
Old 11-16-2012, 06:38 PM
cheezit's Avatar
cheezit
cheezit is offline
ficm is custom, pcm is going to get a roll back too.
another issue is my truck has gained a little weight too.
Mcrafty1
04-29-2016 05:20 PM
TheDuke
02-05-2014 09:50 PM
mmenzies
05-14-2011 02:02 PM
amdriven2liv
07-09-2010 10:48 PM
uscghutch
06-23-2007 04:55 AM
Quick Reply: EGR Delete?
