help axle seals leak still???
Old 11-15-2012, 07:47 PM
fordsrawesome's Avatar
fordsrawesome
fordsrawesome is offline
Hey guys I have a 78 f150 4x4 and I replaced the axle seals and two weeks later the drivers side leaked and it leaks at random I checkeed my vent tube and its fine so just wondering if y'all had any ideas
Old 11-15-2012, 08:08 PM
Broncoboy100's Avatar
Broncoboy100
Broncoboy100 is offline
Check the axle where it rides on the seal, use a micrometer it should be within .0002, any more than that replace the axle.
Old 11-15-2012, 08:16 PM
fordsrawesome
Wow didn't,t think I would need to replace axle it doesn't,t leak bad just alittle
Old 11-15-2012, 08:24 PM
Broncoboy100
After years of the axle spinning on rubber, it will wear the metal down, had the same problem on my '66 Mustang I had several years ago. The seal wore into the metal .0004" and allowed the oil to leak past the seal. I replaced the seal 3 times before I figured out it was the axle worn down.
Old 11-15-2012, 08:46 PM
montana_highboy's Avatar
montana_highboy
montana_highboy is offline
No need for total axle shaft replacement, just "Speedi-sleeve" it...
Speedi-Sleeve shaft repair kits
Old 11-15-2012, 08:54 PM
thekingofcows's Avatar
thekingofcows
thekingofcows is offline
Generally Speaking, if the seal surface of the axle shaft, or sector shaft or any shaft in question is pitted or rough, it needs to be sleeved as mentioned above, or if you have access to a lathe, you can chuck the axle in the lathe and polish the seal surface with sandpaper, or emery cloth progressively working for a finer and finer surface.
Also, when installing the seal, be sure to put a ring of silicone around the outside of the seal as extra protection against leaks.
Old 11-16-2012, 09:49 PM
kenny nunez's Avatar
kenny nunez
kenny nunez is online now
Thumbs up oil leak
I second Montana, I have used "Speedy Sleeves" with 100% success. These things really work , I always coat the shaft with sealer before installing the sleeves. Bearing supply houses usually have a good stock of them. Kenny Nunez
Old 11-17-2012, 11:02 PM
fordsrawesome
That sounds like a good idea guys how do u install those u gotta take shaft out?
Teamrope
11-05-2018 10:22 PM
mark996
01-25-2014 11:46 AM
Liquid10Rider
05-08-2011 09:40 PM
golfpetty
05-18-2009 07:26 PM
Quick Reply: help axle seals leak still???
