Fuel pump leaking - Ford Truck Enthusiasts Forums
Fuel pump leaking
Old 11-14-2012, 11:00 PM
ihf-350's Avatar
ihf-350 ihf-350 is offline
ihf-350 is starting off with a positive reputation.
Fuel pump leaking
Ok I noticed everything under my truck covered in diesel a few days ago then noticed at idle there was almost constant drops coming from numerous locations which was the runoff so I replaced the lift pump tonight pain in the a$$ btw and was just woundering if anybody has ever seen a mech pump leak where the cast meets the sheet metal I thought that was a pretty tight seal there
And there was fuel every where even dripping from the tray under the radiator
Also here are the pics of the new and the new hoses
Old 11-15-2012, 01:00 AM
kc0stp kc0stp is offline
kc0stp is starting off with a positive reputation.
Mine leaked from the same place shortly after I got the truck although it didnt spray fuel everywhere just a nice constant drip under the truck at idle (didnt climb under it while driving down the road to see how bad it was not idling )
Old 11-15-2012, 01:26 AM
ihf-350's Avatar
Ya everything got a nice healthy coat of diesel thats my next to-do clean all that crap up which will be full the fan was throwing it all sorts of directions even had some on the drivers side frame right at thr shock and I could smell it burning off onthe manifolds :-(
Old 11-15-2012, 04:45 AM
joshofalltrades joshofalltrades is offline
joshofalltrades has a good reputation on FTE.joshofalltrades has a good reputation on FTE.
mine used to leak from the same place, and it destroyed just about every rubber component it touched, shock absorber bushings, axle pivot bushings, radius arm bushings, engine mounts, bump stop, etc. some of these were found right away, others were found later. here, take a look at how bad it screwed over the axle pivot bushings, which i replaced over a year after fixing the bad lift pump http://dl.dropbox.com/u/39418460/Pic...811_175257.jpg i wish i would have noticed them sooner!
Old 11-15-2012, 05:37 PM
tecgod13 tecgod13 is offline
tecgod13 is gaining momentum as a positive member of FTE.tecgod13 is gaining momentum as a positive member of FTE.
Yup diesel can eat through rubber!
On the plus side, diesel covered parts don't rust ;-)
The fan will throw it all over the place and it make it seem like a much worse leak than it really was.
Fab Four Bumper w/Rigid LED Lighting Chad149 6.7L Power Stroke Diesel 8 03-01-2013 11:28 PM
Fuel leak from filter fittings ihf-350 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 1 11-12-2012 09:48 PM
Installed a drop axle on my 50 F1 second_chance.custom 1948 - 1956 F1, F100 & Larger F-Series Trucks 1 05-29-2012 01:25 AM
New Paint job ihf-350 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 4 03-17-2012 01:43 AM
Taking Inside and Dash Apart -- ALOT of Broken Stuff -- Questions and Pics 78f250_rls 1973 - 1979 F-100 & Larger F-Series Trucks 11 03-30-2008 05:59 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
