1986 ford f150 - Ford Truck Enthusiasts Forums
1986 ford f150
Old 11-14-2012, 07:08 PM
1986toughf150 1986toughf150 is offline
1986toughf150 is starting off with a positive reputation.
1986 ford f150
i have a 1986 ford f 150 with a 302 in it. when i drive it and let off an keep it at a steady throttle it cuts out then comes back to life. any ideas what it would be??? thanks
Old 11-14-2012, 08:28 PM
85lebaront2's Avatar
85lebaront2 85lebaront2 is offline
Old School Hot Rodder
85lebaront2 is a splendid one to behold85lebaront2 is a splendid one to behold85lebaront2 is a splendid one to behold85lebaront2 is a splendid one to behold85lebaront2 is a splendid one to behold85lebaront2 is a splendid one to behold
It could be your TPS (Throttle Position Sensor) on the early EFI systems they are real touchy on adjustment. The only adjustment is the idle stop screw and it has to be set to 1.0 volt measured at the center lead. If you can't get it there, then it will need replacing. Do not use an aftermarket, only a Motorcraft one will work correctly!
Old 11-14-2012, 08:47 PM
ctubutis's Avatar
ctubutis ctubutis is offline
ctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputation
I would think the first thing to do would be to check the codes, no?
But you (Bill) are an industry expert, so I will defer to your knowledge.
Old 11-14-2012, 08:51 PM
Chris, codes may or may not show anything. What he is describing sounds like the nightmare Matt had with his 86, that was one of the symptoms.
Old 11-14-2012, 09:11 PM
thanks guys i will try that
Old 11-14-2012, 10:01 PM
ctubutis's Avatar
This might help:
Fuel Injection Technical Library Throttle Position Sensor (TPS)
If you're interested in seeing what the computer has to say:
Fuel Injection Technical Library How To Run a Self-Test
1986 XLT Dash emblem bills86f150 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 29 03-02-2012 11:43 PM
1986 ford f150 4x4 shifting pattern 1986 ford blue f150 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 10 08-24-2011 01:24 PM
Manual for a 1986 F150 outlaw_QDK 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 2 01-29-2011 07:44 PM
1986 ford sesquicentennial edition paintdad 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 1 09-09-2009 02:56 PM
1986 Ford F150 Fuel Filter karendon97838 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 4 06-29-2007 06:49 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
