PCM FAILURE - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
PCM FAILURE
Old 11-14-2012, 04:40 PM
coreymck's Avatar
coreymck coreymck is offline
coreymck is starting off with a positive reputation.
PCM FAILURE
He guys I made the big rookie mistake today I pulled my chip out while my truck was on and it shut down
Took the battery cables off an tried with and without chip still didn't bring up the wait to start light and I didn't here the fuel pump I found a used one that is a 422 is it ok to just swap it or do I have to flash the computer also could it be something else it's a 2000 7.3 f250 4x4
Old 11-14-2012, 05:52 PM
Shake-N-Bake's Avatar
Shake-N-Bake Shake-N-Bake is offline
Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.
It's possible that you can simply take your existing PCM to the dealer and have it reflashed and it may work again.
What is the PCM code on your existing unit and what is the code on the used one you found? It will be 3 alpha characters and a number.
Old 11-14-2012, 06:23 PM
coreymck's Avatar
Well I don't know the used ones # but the guy siad the only sting that matters is the dpc # witch is 422 on both units also I am correct this thing is fried right
Old 11-14-2012, 06:25 PM
coreymck's Avatar
The truck was running when I pulled the chip out and it shut off instantaneously and the wait light wouldn't come on as well as I didn't here the fuel pump at all
Old 11-14-2012, 06:26 PM
coreymck's Avatar
Also should I hook my scanner up to it to see I I got a code stored for the failure and if so should I clear it
Old 11-14-2012, 09:17 PM
It's likely that your engine will start and run with DPC-422 but you could have drivability issues and a bunch of weird codes. For instance, the programming is different between pickups and chassis cabs, auto or manual, 2WD or 4WD etc...
If then WTS light isnt coming on the PCM is not awake. I wouldn't say "fried" but certainly not healthy.
If your scanner connects then your PCM is most likely fine and you have some other issue.
Old 11-15-2012, 07:34 AM
coreymck's Avatar
So the used one is a pcm pct2 I have a pct3 I heard that the pct1 is the best one for shift patterns but really don't know what the differences are between em all
Old 11-15-2012, 09:15 AM
I'm not sure either. Your tuner can probably give you more details about the differences between the various calibrations. There are over 400 different PCM calibrations that I am aware of....
That is why I was suggesting that you have your dealer or tuner reflash your existing PCM. It's likely that your chip was programmed for your particular PCM code so it's worth keeping things the same in my opinion....
Old 11-15-2012, 12:44 PM
coreymck's Avatar
Plugged it in and fired up no problems yet
Ts6 install help BigBlackF-250 1999 - 2003 7.3L Power Stroke Diesel 3 10-19-2015 05:28 PM
Chip ? 1950gmcelc 1994.5 - 1997 7.3L Power Stroke Diesel 7 06-30-2014 09:55 AM
Performance Chip with out a DPF delete KR250 6.4L Power Stroke Diesel 17 01-27-2014 10:56 PM
Good or bad? Vinford 6.4L Power Stroke Diesel 125 11-30-2013 11:00 AM
Chip Foose drew a picture of a Bronco on my T-Shirt. Red Ford Truck Ontario Chapter 4 02-14-2008 06:51 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
