429/460 identification help with casting #'s
We just got done pulling a BB out of a newer mustang, this was supposed to be a 429 set up but were not sure.
Block casting # DOVE-A
The only thing is it looks like 460 is imprinted from the inside of the block on the drivers side near the timing cover is this normal?
Head Casting # D00E-R
Any info or all info on these parts would be greatly appreciated.
Just by those two casting numbers....you are correct, it it could very well be a 429CJ/SCJ. With it being a D0VE-A block, then it sounds like a 70 model engine since the 71 used the D1VE-AA block.
Does it have a stock oil filter threaded adapter with external threads or does it have an adapter with internal threads? Or does it have an oil filter adapter bolted on?
The SCJ used forged pistons with one valve relief. The CJ used cast pistons with two valve reliefs. Both used adjustable studs with 351C style rocker arms. I believe the CJ was a hydraulic cam where as the SCJ was mechanical/flat tappet/solid lifter. The CJ most likely is a 2bolt and for as I know, all SCJ were 4 bolt blocks. The cranks and the rods are the same as most every thing else except the intake. The CJ used a Q-Jet style carb with big secondaries and the SCJ used a Holley.
Everybody's right, (the CJ was non-adjustable valve-train after the first production run, but easily changed with locking rocker arm studs) but the crank is the only sure way to tell if it's still a 429.
As Larry points out, the CJ was little different than the Thunderjet with the exception of DOOE heads and some bolt-ons. A Ford service bulletin in 1970 spec'd forged SCJ pistons as service replacements for the CJ as the cast pistons were breaking skirts, primarily in police applications running at extended high rpms.
Nice find as only about 20,000 sets of DOOE heads were cast and pullers/mudders restricted to iron heads have driven their market price up to that of aluminum aftermarket heads.
FordTrucksKickGM
06-29-2006 05:05 PM
69ragtop
08-03-2005 10:21 PM
ivanribic
01-24-2004 05:38 PM
