DOHC 5.4 into a '97-up F150
Greetings. I needed information and specs on putting a DOHC Lincoln Navigator ('99-up) engine into an F150. I know it seems like a pretty straight forward bolt in swap since the chassis are the same (aren't they?), but what I really need to know about is the electronic end of it.
Will I need a new PCM, wiring harness, that sort of thing.
I thank everyone in advance.
I'm also planning on putting a Navigator 5.4L DOHC engine into my 1997 F150. You mentioned that the computer and harness would be required, but would I have to make changes to the transmission?
I was under the impression that I would also have to get a transmission from a 2WD Navigator. Would the 4R70W transmission that came with my truck work alright with the Navigator engine?
Thanks in advance.
Thanks in advance.
79 f-150 guy
Modular V8 (4.6L, 5.4L)
12-03-2009 07:48 PM
