Cannot get the crank pulley off tool needed - Ford Truck Enthusiasts Forums
Old 11-14-2012, 04:06 AM
fordf350camper's Avatar
fordf350camper fordf350camper is offline
fordf350camper is starting off with a positive reputation.
Hi i am trying to get the crank pulley off my ford 223 engine but no luck.I have tryed to use a hub puller but no luck.I have looked in the manual and its says there is a tool that you use.Help but i am in the uk so lending,hire i dont think will happen.I have tryed and tryed but it will not come off thanks
Old 11-14-2012, 10:46 AM
vntgtrk's Avatar
vntgtrk vntgtrk is offline
vntgtrk is starting off with a positive reputation.
Have you put an impact wrench on the puller? I got mine off with my steeering wheel puller set and my 3/8" drive impact. Worked great except I didn't put the cone on the end and messed up the threads on the crank. I was able to chase them, but it's a rookie mistake and I shoulda known better.
power steering pulley installation tommyblack 2004 - 2008 F150 2 01-08-2015 01:02 PM
Fan clutch removal, a new trick! akamacgyver Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 15 04-18-2013 05:41 PM
Vacuum Pump Pully Removal sailorjohn 1999 - 2003 7.3L Power Stroke Diesel 3 12-10-2011 02:10 PM
Crank pulley removal way2fast1 1948 - 1956 F1, F100 & Larger F-Series Trucks 10 05-29-2011 01:10 AM
351w and pulleys JCastellaw 1966 - 1977 Early Broncos 11 10-19-2006 03:34 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
