1994 F150 Front end wobble
My son's 1994 F150 has a violent wobble on the front end left to right from time to time while cruising 35 to 70 mph. He can correct it by steering back and forth, right to left quickly. This occurs on both tires at the same time. (straight 6; 300 cubic inches; automatic trans). He has some money set aside to do some repairs and would like some pointers on where to start looking before he begins to spend money.
Thanks for feedback, all is appreciated.
Worn tie rod ends, worn steering gear box, worn ball joints, bad tire (shifted belt) or out of balance tire...
Get under it and have someone turn the steering wheel back and forth.. Watch the items mentioned above, I'll bet you will see where some of the lost motion is.. For the ball joints jack it up by the axle and shake the top and bottom of the tire in and out, and again look for lost motion. You can also use a pry bar to lift up on the bottom of the tire while it's jacked up to check for lost motion..
cheers
Dycrow27
03-01-2013 08:23 PM
Ford-Trucker84537
1999 to 2016 Super Duty
08-24-2007 06:42 PM
HIDEE101
02-08-2005 08:10 PM
