Vin decode help please
Old 11-13-2012, 03:42 PM
Nr8l's Avatar
Nr8l
Nr8l is offline
Hello all! I have a custom cab unibody that I beleive is a 1963, but not positive. Any help would be great.
Vin# f10cr393788
Thanks
Old 11-13-2012, 04:54 PM
Nr8l's Avatar
Nr8l
Nr8l is offline
Also
Body. 66b
Color y
Axle. 12. (9 inch 389) i think
Old 11-13-2012, 06:56 PM
garbz2's Avatar
garbz2
garbz2 is offline
F1 =F100
C=282 2V
R=San Jose assembly
393788= born in the moth of March 1963
66B= Integral Body. B=Custom Cab
Y=Glacier Blue M30j-1553
12=3.89 9" open rear
Welcome to FTE
Garbz
Old 11-13-2012, 07:59 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Originally Posted by garbz2
F10 = F100 2WD
C = 292 2V
R = San Jose CA Assembly Plant.
393788 = born in the month of March 1963.
66B: 66 = Integral Body / B = Custom Cab.
Y = Glacier Blue.
12 = Ford 9" Rear Axle / 3.89-1 / no Limited Slip / 3,300 lb. Rear Axle Capacity.
Welcome to decoding.
Old 11-13-2012, 08:43 PM
garbz2's Avatar
garbz2
garbz2 is offline
I was close.....
Garbz.
Old 11-13-2012, 10:08 PM
Nr8l's Avatar
Nr8l
Nr8l is offline
Thank you gentlemen! It seems this truck is fairly rare, I cant find any others. Your thoughts?
Old 11-13-2012, 10:56 PM
jacks61ford's Avatar
jacks61ford
jacks61ford is offline
I have two of them lol
Old 11-14-2012, 02:29 AM
NumberDummy
40,535 F100 Uni's assembled in 1963.
Old 11-14-2012, 12:51 PM
arctic y block's Avatar
arctic y block
arctic y block is offline
Uni's are nice. But not rare. Check mine out in my Album.
Quote:
Originally Posted by 76f350spercamprspeal
Welcome to FTE, Best Damn Forum EVER!
Here's How to Post Pictures:
1. Login to FTE.
2.Click User CP (In the Top Left Hand Corner)
3.(On the Left, There will be a list, The 5th Option Down, will say "Pictures & Albums) Click That.
4.Then, Click Add Album, Enter a title, and description, if ya want to.
5. Click Upload Pictures, Then click Browse, Locate the Files of your truck. (You can add 3 files at a time)
5. Click Upload.
6. Add a description to the individual pictures, then click save.
7. Add more files if ya want.
8. Click The Picture you want to post, it will give you two codes at the bottom, Right Click The Second one (It say's BB Code, Then Say's [IMG]http:blahblahblah...[/IMG])
Then, Once that is highlighted, Right Click, Then Copy, Then Paste it into your post.
You can add up to 30 Images in one FTE Post.
If, Ya need any help, Don't hesitate to ask.
Quote:
Originally Posted by old_dan
You can also go to the "Garage" tab and start an album right here on FTE. After you post pictures to an album, we can look in your album, but you'll also be able to "insert a picture" by pasting in a link to the picture in your album.
It seems awkward, but whenever you "insert a picture" to one of these threads, the forum is looking for the picture somewhere on the web (which is always available) rather than from somewhere on your hard drive (which isn't always available).
Quote:
Originally Posted By Jolly Roger Joe
Welcome to FTE!
Go to Image hosting, free photo sharing & video sharing at Photobucket and sign up for a free account. Then create an album for your truck. Upload any pics you want to post on FTE to that album. Have this album open on your computer when you want to post pics on FTE.
While you're making a post on FTE, select the pic you want to post from your Photobucket album. When the large version of the pic is open, right mouse click on it and select "View Image Info". The image info will be highlighted and will look something like this:
http://i285.photobucket.com/albums/l...ghtsafter1.jpg
Copy that highlighted info (right click / copy).
When you have the spot in your post where you want the pic to be placed, select the "Insert Image" icon at the top of the post (looks like a mountain) and paste (right click / paste) the image info you copied in the highlighted box (just shows "http://" when it opens).
Your pic will be placed in the post.
Hope that helps.
Here's a tutorial Bob put together: https://www.ford-trucks.com/forums/67...-pictures.html
Old 11-14-2012, 03:43 PM
camperspecial65's Avatar
camperspecial65
camperspecial65 is offline
the truck IMO would be rare/signifigantly less common if it is a shortbed truck. The color combo coupled with a shortbed may make it less common as well.
Given the total number of pickup trucks made in 1963 also factor in as well...compared to the huge number of trucks made nowadays make most any pickup made in the 60s rare...but given the attrition rate over the years etc...its a less then common truck...
A great example would be paint for example...certain color combos on tutone trucks werent allowed per the brochures...I, however have a tutone white truck that wasnt special ordered...and tutone white was one combo specifically mentioned as not being available in 1965...alone with chrome yellow as well...gotta love fine print:-)
So it depends on how one looks at rarity as we all look at that differently.
- cs65
Old 11-14-2012, 05:48 PM
Nr8l's Avatar
Nr8l
Nr8l is offline
Thanks. I wasn't all that clear. It is a swb, custom cab. That is the combo that I was not finding any of.
Old 11-14-2012, 05:49 PM
Nr8l's Avatar
Nr8l
Nr8l is offline
Numberdummy, an idea how many of that particular truck made?
Old 11-29-2012, 11:07 PM
kjvforme's Avatar
kjvforme
kjvforme is offline
You need to hook up with deflaytedwayz, his truck was right in front of yours on the assembly line.
Old 11-30-2012, 10:28 AM
TA455HO's Avatar
TA455HO
TA455HO is online now
I found the post from him and NDs decode here.
https://www.ford-trucks.com/forums/5...l#post11313965
Both Glacier Blue, too...
Old 11-30-2012, 11:02 AM
TCAPer's Avatar
TCAPer
TCAPer is offline
I don't know how Ford ran the assembly lines back in the '60s, but the trucks are not built in numerical order by VIN numbers. They run them in a special mix so the assembly line does not get over-whelmed by a special option. At Twin Cities Assembly (Ranger), they couldn't just run all 4door SuperCabs in a row. They mixed in the base (fleet model) Rangers to balance it out....
Quick Reply: Vin decode help please
