ScanguageII mounting
Installing in an Ex. which I think is nearly the same as the f250's and up.
Where is everyone mounting their scanguageII? I just recieved mine and have not messed with it much yet. I want to make sure I place it where it is easy to use and still visible while driving.
If you just used the velcro, where did you locate it and how do you like it there?
I have seen the blendmount - just seems a little rich, but I like the location.
I saw a few months back where someone had a frame for the SGII, just dont remember much about it, not even 100% sure it was on this sight. Anyone recall this?? Seemed like a member was selling them.
I've got a blendmount now but previously had it located below the headlight switch and held by two strips of velcro. That location worked out fairly well overall and having it at the junction of the two panels allowed for better retention with a velcro strip on each panel. You can see the old location in the bottom-left of this picture:
That's a good spot. Glad I saw your pic, I was thinking of drilling through the panel and putting the wire through it from the back of the scan gauge either in the same spot as yours or on the right under the a/c vent.
AtlantaBoy
05-04-2015 12:29 PM
Matt1966
08-17-2013 03:50 PM
Profold
08-11-2011 01:01 PM
