Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > International Region > Australia Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Australia Chapter Join Chapter , Leader: ChunderDownUnder
  #1 (permalink)
Old 11-13-2012, 03:18 AM
SSSimon SSSimon is offline
2005 Ford F-250
SSSimon is gaining momentum as a positive member of FTE.SSSimon is gaining momentum as a positive member of FTE.
Best toons for a 6 pos tuner?
Vehicle has 4" turbo back, 6637 air filter, AIH delete, high flow turbo outlet, aramid IC boots, IH up-pipes, overboost code regulator. The current Superchips achieves 25psi of boost. Fuel pressure in the bowl is over 60psi - running lift pump, water seperator, Hutch mod. Have stock injectors, turbo & HPOP. I'm also running guages so I keep an eye on the EGT and trans temp.
The sort of tunes I'd like:
1) Quiet - speed limited to 100kmh (in case I let my son drive - but I'll have to hide the switch);
2) stockish with nice user friendly throttle response and max fuel economy;
3) Economy tow - towing up to 3.5 tonne;
4) Heavy tow - safe towing up to 4.5 tonne;
5) Mountain/'sport' driving - higher shift points, max low down torque
6) Max power - with only the faintest hint of coal (overtaking tune).
__________________
Mods done: lots of cheap mods (Hutch, IC boots, plenum inserts, IH uppies, HPx, AIH delete, EBPV delete, hi flow outlet, CCV mod, OCR, Superchips, Zoodad, 6637, 4" TB exhaust, JW valvebody, coolant filter, FRx, '05 HD lights with switch bypass relays, B100 ready fuel system)
Mods NOT done: big oil, big brakes, big turbo
Next mods: ? tuner, G2WW (on the shelf), alloy diff covers
Australia: where Mechanics use spanners and Plumbers use wrenches...
  #2 (permalink)
Old 11-30-2012, 09:41 PM
Diesel Submariner's Avatar
Diesel Submariner Diesel Submariner is offline
2005 Ford F-250
Diesel Submariner is gaining momentum as a positive member of FTE.
PHP 6 POS
G'day Simon,
Not sure what you have done about this?
But I went with a PHP FU2 6 Pos change on the fly chip.
I've had it in for a few years now and done a lot of towing and outback running with it and I've been very happy with it .
I went with the following tunes:
25Hp Extreme Heavy Duty Tow & 4WD
40Hp Heavy Duty Tow
65Hp Medium Duty tow
80Hp Light Duty Tow/Truck alone at GVM.
80Hp Daily Driver
100Hp Performance
The 80Hp DD is my main tune for normal driving around and has plenty of get up & go.
The 100Hp performance is a good aggressive tune and sits you back in the seat if you punch her.
It breaks down like this:
Gross Combined Weight Rating (GCWR) Gross Combined Mass (GCM) That is the Truck Weight (Mass) + Trailer Weight (Mass) = GCWR or GCM.<O></O>
  • 25hp - Over 20,000lbs (9,071kg) GCWR (all terrain) <O</O
  • 40hp - 16,000 to 20,000lbs (7,260 to 9,071kg) GCWR (all terrain) <O</O
  • 65hp - 12,000 to 16,000lbs GCWR (5,450 to 7,260kg) (all terrain), 16,000 to 20,000lbs (7,260 to 9,071kg) GCWR (flat terrain) <O</O
  • 80hp - 8,000 to 12,000lbs(3,630 to 7,260kg) GCWR (all terrain), 12,000 to 16,000lbs (5,450 to 7,260kg)GCWR (flat terrain) <O</O
  • 100hp - 8,000 to 12,000lbs (3,630 to 7,260kg) GCWR (flat terrain) <O</O
  • 120hp - Not Recommended without a heavy duty gearbox & forged rods. <O</O
  • 140hp - Not Recommended without a heavy duty gearbox & forged rods. <O</O
Keep in mind that files designated as "Tow" are designed specifically for the needs of towing (shift strategies, pressures, lockup, fuel curves, injection timing) while "Performance" programs are handled quite a bit differently.
Hope this helps.
Cheers,
Reg.
__________________
Aussie spec 2005 (US 2003) F-250 SD 4x4 7.3Ltr Powerstroke: PHP FU2 6 Pos’n Chip,6 x ISSPRO Guages, AIS Intake, Zoodad, Hutch'd n’ Harpoon'd. Cowl Hood, AIH Delete, CCV, RiffRaff FRx,HPx,OCR, JWVB. ARB Air Lockers Front & Rear,V10 Tranny cooler + Stock Tranny cooler, ARB Bull Bar. Long Range Fuel Tank,VMS in Dash GPS Nav.OME Suspension & Dual Tower Shocks, MOOG Ball Joints. GVWR (GVM) Upgrade to 5,000Kg (F350+).
  #3 (permalink)
Old 12-01-2012, 04:59 PM
ChunderDownUnder's Avatar
ChunderDownUnder ChunderDownUnder is offline
Garage is empty, add now
ChunderDownUnder has a great reputation on FTE.ChunderDownUnder has a great reputation on FTE.ChunderDownUnder has a great reputation on FTE.ChunderDownUnder has a great reputation on FTE.ChunderDownUnder has a great reputation on FTE.
Im realising that there is no such thing as "best tunes" in regards to tuners. I have had the DP and Im now running gearheads tunes. There are pro and cons on both. I really believe the "best" part of it will come in there after sales support. Because of our location you really need some one who will go that little bit further in regards to tweaking there tunes if you find a problem. So that limits you to the 6 position TS chip. I didnt like the noise from the engine and the touchy throttle on the DP and you have to send the chip back for any changes. Gearheads shift strategy (now this is my opinion) is all over the place. The truck has nice throttle response and goes like a scolded cat but it is very difficult to drive under Australian speed limits (specifically 80kph) with the way it changes gears. Im in discussions with him now but its dragging out longer than I like. Whom ever you go with just make it crystal clear that if you need changes that they are willing to do so and do it via email. I would speak to Clay as well cause he seems to be happy with the tunes on his new engine. I cant remember who it is tho.
__________________
Brian
03 F250 XLT LB . Full Engine build with all the goodies. Tuned by Matt
- cant wait until my motor blows so I can blame someone else -
join the Australian Chapter here-Join Chapter
  #4 (permalink)
Old 12-01-2012, 09:05 PM
2005 Ford F-250
PHP FU2
G'day Fellas,
Your dead right mate tunes are very much a personal choice made after your own research to match your very individual needs.
Your point about our Downunder distance disadvantage is not wasted as one of those important decisions to be made on what/who you go with.
I had no issues with PHP getting back to me when initially working out my tooons.
The FU2 package is for more heavily modified trucks and they won't sell it to you unless you've done at least the minimum mod to the slush box with a modified valve body (JW, BT etc).
It is a custom chip with the total of your mods (VB, intake, exhaust, Tyre size etc) and your purpose (towing, DD, racing, pulls etc) taken into account.
Any changes you would like to make is done by Bill and emailed to you to burn onto your chip as a burner comes as part of the package. This eliminates the agonising wait of some where you have to take your chip out and post it over to the US get new tunes burnt and wait for it to return. Meanwhile your back to Stock.
As you say what ever you go for, make sure it's for right for you and fit for trucks intended use.
Cheers,
Reg
__________________
  #5 (permalink)
Old 12-04-2012, 02:26 AM
2005 Ford F-250
The kid in me wants a 'Lumpy Idle' tune for pulling into the hardware store
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
