1949 F3 - I'd like to move the gas tank out of the cab.
When I first got my 49 the PO had done something similar to what you are talking about. In my case they didn't do a very good job of it. They basically took the tank out of the cab, turned it around and bolted it to the front bed panel. After that they took a piece of 1/8" thick sheet metal and welded that between the bed sides to protect the tank from stuff in the bed.
It can be done and done well. I've seen several trucks at truck shows that have built in boxes in the bed that combine storage and fuel tanks.
This video is not of a pickup but it is in Russia where the crash standards for automakers have been almost non-existent. http://www.liveleak.com/view?i=e22_1347381858
So if you relocate the tank to the rear I would make sure that there is nothing around it, like a bolt or non-reinforced trailer hitch that could penetrate the tank in a crash. And if you are using a plastic tank you might want to think about installing some sort of shield. Here is what happens when the design is inadequate: Gas Tank Explosions - Crown Victoria Police Car Explosions
If you do move the tank to the rear I would also make sure that you have a stout rear bumper which leave out those that want to go bumper-less.
Since rear end collisions are the most common type of accident (see second paragraph) you might want to put some extra thought into gas tank relocation. You could be making things worse.
Hey Pete,
All the manufacturers took the tank out of the passenger compartment - not a vote of confidence for keeping it in there. I definitely agree that you need to put some support around the tank if it goes in back. Our truck's gas tank support in pic.
Ben in Austin
1950 F1
Ben in Austin
1950 F1
I'm not being critical of your design as I'm not there looking at it, just pointing out potential pitfalls that we all need to think about. Eventually I would like to move my tank out of my cab but I have to finish all the other work that I started on it first. Little things like getting it to run, steer and stop . . . when and where I want it to go.
Hey Pete,
Our's is the 1970 Mustang 22 gallon tank used by quite a few folks on here. We used Jniolin's specs for our install then put in some fairly serious support around the tank & it's inside the frame. That's about as good as we could do it. Still always a risk....
Good luck on your build. If you use this tank don't make the mistake we made - see that nice round spot up on top of the tank in this pic. If you use aftermarket gauges you need to stick an aftermarket sender in there - our Christmas project now since I overlooked that the first go round. Grr...
Ben in Austin
1950 F1
Ben in Austin
1950 F1
Hey Pete,
Ben in Austin
1950 F1
Ben in Austin
1950 F1
Thanks again for the pix.
