Power Steering Pressure hose and fitting
I have a 78 1/2 ton 4x4 with a 460 and I started leaking fluid around the pressure line where it goes into the reservoir. There is a fitting that goes into the reservoir then the line has a fitting on it that screws into the fitting the goes into the reservoir. The fitting on the hose is the one that is leaking.
I'm a shade tree mechanic at best, but for some reason I can't get the fitting that screws into the reservoir to screw back in. It came out no problem and the threads are fine, but it won't go.
If I take my finger and push up into the reservoir hole I could feel something that felt like a small cylinder that was spring loaded. After several attempts this weekend to get the fitting threaded back in the reservoir this small cylinder just fell out. I simply pushed it back in and it went in and stayed and still feels as though it has a spring behind it.
So my question is why the hell won't this thing thread back in and what is the piece that fell out?
Thanks in advance for any help
hrc200x
08-21-2018 07:22 PM
Dutter 2
05-28-2018 08:53 PM
Blown 331
09-26-2010 07:19 PM
WILDMAN_Stroker*7.3
08-02-2009 10:37 AM
