Cant believe I don't have a pic of this upon dis-assembly, but where does the negative cable ground to the body??
1950 F1..
Thanks
Is your truck converted to 12 volts?
If it's stock, 6 volt positive ground, the negative cable goes to the starter solenoid/relay. The positive cable goes to the engine block on mine, and another ground should go from the engine block to the cab or frame.
