Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1948 - 1956 F1, F100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
1948 - 1956 F1, F100 & Larger F-Series Trucks Discuss the Fat Fendered and Classic Ford Trucks SPONSORED BY:
  #1 (permalink)
Old 05-21-2003, 07:51 PM
ddurant's Avatar
ddurant ddurant is offline
Garage is empty, add now
ddurant is starting off with a positive reputation.
fire wall sound proofing
i have added carpet to my 49. there is a company that computer cuts it to fit your truck. i am very pleased with it. i know it is not stock but it came with 1/2 ' padding attached and some kind of rubber looking heat and sound shield. i would like to but somthing on the fire wall to further cut down on the sound. do you know of any company that has this. midfiftys has one but the say it wont fit
__________________
Dale
Richmond, VA
49/51 F-1
89 Bronco II
04 F-150 4x4 lariat screw
  #2 (permalink)
Old 05-21-2003, 11:40 PM
DS02F250 DS02F250 is offline
DS02F250 is starting off with a positive reputation.
Dale,
I used "Dyno-Mat". It is a sound-deadening dense rubber sheeting that is rubber on one side (face down on the metal) and a silver "aluminum foil" looking covering on the other side (which goes face-up on the install). It's a cut-to-fit deal, as Dyno_mat comes in pre-set lengths and width rolls. Install is strainght forward: measure areas to cover, cut Dyno-Mat to size (maybe a bit larger just to be sure. You can always trim any excess), the apply with a heat gun for great adhesion to the metal surface of the interior of your truck! It can be used all over the interior: floor, firewall, doors, rear, headliner... And it really helps the sound system by dampening motor and exterior noises.
There are other similar products by different names. Should be able to find via Internet.
Good luck,
Daryl
  #3 (permalink)
Old 05-22-2003, 02:21 AM
Aekisu's Avatar
Aekisu Aekisu is offline
Aekisu is starting off with a positive reputation.
I just finished up a (now don't shoot me) 1970 VW Bug. I lined the whole interior with a product I found at Home Depot.
It is a 1/4" self-sticking foam air ducting insulation, with a foil backing. One small piece, on the inside of the door, produced the oh so desired "thunk", when you close the door.
I did the interior of the roof before I put in the headliner, floorpans, firewall, etc. The stuff is dirt cheap and very effective for cutting down on the noise factor.
__________________
Dennis
The Oldman's Home Away From Home
  #4 (permalink)
Old 05-22-2003, 09:33 AM
tgregoire tgregoire is offline
tgregoire is starting off with a positive reputation.
Aekisu,
Any idea what the actual name of the insulation from Home Depot is? I went there and asked for this type product and just got a blank stare. I searched around for it and couldn't find it.
Thanks
  #5 (permalink)
Old 05-22-2003, 12:57 PM
Jag Red 54's Avatar
Jag Red 54 Jag Red 54 is offline
Jag Red 54 is gaining momentum as a positive member of FTE.Jag Red 54 is gaining momentum as a positive member of FTE.
I like to use the double-foil insulating material available at Home Depot or OSH Hardware. It comes in bulk rolls at OSH so you can buy just the amount you need. It comes in 4' or 2' widths. In between the thick reflective foil layers is a 1/4" bubble plastic material. It really helps with the noise/heat and it is easy to trim to fit. John
__________________
54 F100
55 Fairlane
68 F100
55 Crown Victoria
  #6 (permalink)
Old 05-22-2003, 02:05 PM
I'm really interested in the adhesive backing. I have some of the normal stuff but was hoping the adhesive backed stuff would be easier to apply.
  #7 (permalink)
Old 05-22-2003, 03:27 PM
Jag Red 54's Avatar
I used "gorilla snot", which is 3M weatherstripping glue. I glued some of the double-back foil under the hood of my Fairlane to protect the paint from the heat of that massive 272. That was nine years ago and it has yet to let go. Good luck, John
__________________
54 F100
55 Fairlane
68 F100
55 Crown Victoria
  #8 (permalink)
Old 05-22-2003, 06:20 PM
fatfenders's Avatar
fatfenders fatfenders is offline
fatfenders is starting off with a positive reputation.
"It comes in 4' or 2' widths. In between the thick reflective foil layers is a 1/4" bubble plastic material."
John
I seriously considered that option. If not for the undeniable truth that my little girl would be stompin some floorboard bubbles as we speak. It's really fun. You ever tried it?
The foil stuff also comes in a "wool like" fiber center that is probably a better choice. Although a bit more expensive.
__________________
'fenders
53 F100
"All Ford" Volare Truck
  #9 (permalink)
Old 05-22-2003, 07:02 PM
Aekisu's Avatar
Quote:
I just walked out to the shop and looked. Sorry but I threw the package away. My best guess would be Frost King. It comes in rolls (approximately 6" diameter) and is 12" wide. The foil is visible from outside the package.
__________________
Dennis
  #10 (permalink)
Old 05-25-2003, 05:44 PM
Scot Scot is offline
Scot is starting off with a positive reputation.
There has been a lot of technical discussion about sound proofing on www.turbodieselregister.com
There are a bunch of people who have done tests using sound meters and one of the prefered materials to use is thin lead. You just form it with a mallet and glue it in!
__________________
'78 F250 4x4 Supercab, Cummins 6bta, NV4500, South Bend clutch, NP205, Dana 70/60. Click on my gallery for lots of build pictures.
'55 F100. 302, Tremec TKO, 9" 4.11 LSD, A/C P/S, disc brakes, cruise, arrest-me red. On the road since 1989.
Tags
classic, depot, fire, forum, heat, home, insulation, lead, shield, sound, soundproofing, truck, wall
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
