Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > International Region > Australia Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Australia Chapter Join Chapter , Leader: ChunderDownUnder
  #1 (permalink)
Old 11-12-2012, 06:29 AM
SSSimon SSSimon is offline
2005 Ford F-250
SSSimon is gaining momentum as a positive member of FTE.SSSimon is gaining momentum as a positive member of FTE.
What mod next?
I've reached the end of the line for mods while retaining the stock injectors, HPOP and turbo. I don't think there's too much left that I can do.
Possibly:
-replace the old Superchips tuner with one of the newer style switchables;
-ditch the single DIN sterio and nav units for one of the newer style double DIN everything units;
-tart up the diff cover/s.
Any other (polite) suggestions?
__________________
Mods done: lots of cheap mods (Hutch, IC boots, plenum inserts, IH uppies, HPx, AIH delete, EBPV delete, hi flow outlet, CCV mod, OCR, Superchips, Zoodad, 6637, 4" TB exhaust, JW valvebody, coolant filter, FRx, '05 HD lights with switch bypass relays, B100 ready fuel system)
Mods NOT done: big oil, big brakes, big turbo
Next mods: ? tuner, G2WW (on the shelf), alloy diff covers
Australia: where Mechanics use spanners and Plumbers use wrenches...
  #2 (permalink)
Old 11-12-2012, 07:57 PM
ChunderDownUnder's Avatar
ChunderDownUnder ChunderDownUnder is offline
Garage is empty, add now
ChunderDownUnder has a great reputation on FTE.ChunderDownUnder has a great reputation on FTE.ChunderDownUnder has a great reputation on FTE.ChunderDownUnder has a great reputation on FTE.ChunderDownUnder has a great reputation on FTE.
save ya money for a new trans.
Seriously tho. I would be very jealous if you got the sbcc break upgrade
http://ssbrakes.com/i-10093222-v8-qu...grade-kit.html
__________________
Brian
03 F250 XLT LB . Full Engine build with all the goodies. Tuned by Matt
- cant wait until my motor blows so I can blame someone else -
join the Australian Chapter here-Join Chapter
  #3 (permalink)
Old 11-13-2012, 02:48 AM
2005 Ford F-250
Geoff (Ratkat) got those. Geoff, how do you rate the SBCC brake calipers?
1) Fit and fitting;
2) Brake performance before and after?
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
