Turbo failure in Sioux Falls SD
#31
Thats what is so great about this forum. Seems like everyone on here is willing to help a fellow member no questions asked. Damn shame the rest of our country can't take lessons from us. Had problems 2 years ago and Camp Springs John was in contact with me from southern IN till I got to Valdosta GA. Comforting feeling when on the road. Just had to give a Shout Out to all the quys out there. Congrats. Jeep Taylor
GLAD the truck is doing good with the new turbo!
#32
Did you guys figure anything out on his truck? If not, put a big rubber tire on the front of yours so you can push him up the mountains! Just kidding, hope his truck makes it home ok.
I'm glad that turbo is working so good for you. It really does make me wonder about that 1.0 housing. I've always heard they RAISED the exhaust temps more. But you said you're boosting almost 500rpm less and you're boosting higher, so I guess that is why they are lower?
Still been wondering how it would work with my setup.
#33
We made it home safe and sound. The old Ford did pretty well. I love that 1.00 housing. The trailer weighed about 20k. I had much higher boost numbers at lower rpms and as long as I kept it below 3200rpms when pulling hard I didn't have any egt problems. It would stay below 1200*. Now for 3.55 geared trucks pulling heavy loads I could see where egts could be a problem. But with 4.10s and having boost earlier, its a perfect combination.
With the 1.15 (stock) housing I would have to keep the rpms near redline to keep power and keep egts down and I still didn't have as much boost or power.
Mikes truck played the same games today. We are pretty sure its the injection pump (cp3) or the reg. We at least got it home pulling the lighter trailer. That thing will run circles around my truck power wise when its running like its suppose to. Thanks again to everyone!!
Darin I would say with stage ones and the 1.0 housing you would probably over boost when pulling and I doubt the turbo would last long. However if the turbo could last with high boost pressure I would say it would be an animal!! I believe Borg Warner makes a ball bearing version of TP38, I think its the TP38R. I bet that would hold up under high boost situations.
#34
Pictures look great Chris. Glad you guys made it back ok and that turbo works as good as it does for you. I never thought of the higher boost numbers than the stock turbo wants when I was thinking of this. I hit 25+ pretty easy on some hills already, in overdrive, with exhaust leaks, which will be fixed soon. I'll just stay where I'm at till I can upgrade to a bigger turbo.
Thanks Chris.
Thanks Chris.
#35
#37
They are probably stage 1's, don't know for sure. If I understand the D66 correctly, its a bigger wheel in a stock turbo so its equivalent to a 1.0 housing. I can get 30lbs out of it. There is no need for you to worry about it taking your turbo out, I pulled heavy with it for several years. I read that the 1.0 can speed up the life span of a turbo but I don't think its that much 'speed up' to be concerned about.
#38
#39
That is the thing Ronnie. Very much of that 33-35 psi and that turbo isn't going to be around long. I rebuilt mine a few years ago and it is in great shape yet. I'm not going to get that housing, just save up for a bigger turbo. I know I would like it for however long it lasted, but it works ok now, so no need to push it anymore.
#40
Thanks Glenn. I am not planning on keeping this turbo when I go to stage ones anyway. I have really been leaning towards the D66 due to it being a bolt on. I get 28psi with the 1.0 housing and stock injectors. I am sure with my towing I would burn it up in no time with stage ones. I have read the stock turbo will only hold 30psi for the long term and going over shortens its life quickly.
Wish I could have done the D66 this time around instead of having to go stock. Oh well, guess I didn't have much of a choice!! haha
#42
#43
