Transmission Temp. Question - Ford Truck Enthusiasts Forums
Old 11-11-2012, 11:40 PM
Craig N Craig N is offline
Craig N is starting off with a positive reputation.
Hey Folks,
I have got about 3000 miles on my '12 5.0L F150xlt 4x4 SCrew. This is the first truck I have owned where I can monitor the transmission temps. I haven't towed with it yet, but the highest temp I have seen is 199. What temps should cause me alarm, and/or what is the acceptable temp range for the tranny. I think it is a 3.55 rear end if that matters. Thanks for all input.
-CN
Old 11-12-2012, 11:48 AM
04XLTRUNNER's Avatar
04XLTRUNNER 04XLTRUNNER is offline
04XLTRUNNER is gaining momentum as a positive member of FTE.04XLTRUNNER is gaining momentum as a positive member of FTE.
I have had my temp up to 218 under really hard driving. Normally it sits between 199 and 204. 25k miles and no issues.
Old 11-12-2012, 02:36 PM
thiggins01 thiggins01 is offline
thiggins01 is starting off with a positive reputation.
Since Ford uses a heat exchanger between the engine coolant and transmission fluid, it's going to always be around what the thermostat regulates. ( What is the factory thermostat temp?) I used to worry about it being 190 - 200, but that's being regulated by the design of the truck, which works I suppose. Sure wish it was closer to 165-170, but that's the way Ford does it. Since I tow quite a bit, I'll be changing the trans fluid more often.
About the only way to get it down would be to either put in a cooler thermostat, or route the transmission fluid to an external cooler, both of which are fraught with calamity.
Old 11-12-2012, 09:37 PM
smokersteve's Avatar
smokersteve smokersteve is offline
smokersteve has a good reputation on FTE.smokersteve has a good reputation on FTE.smokersteve has a good reputation on FTE.
If you get to 220 then your pushing it too much
Old 11-12-2012, 10:44 PM
Quote:
I figured I was getting it a little on the high side. It cooled back down quickly but I wasn't to comfortable with it sittin at 218 for more than a couple seconds. Does anyone what the actual limit is before damaged is caused
Old 11-12-2012, 11:13 PM
BigDfromTN's Avatar
BigDfromTN BigDfromTN is offline
BigDfromTN is gaining momentum as a positive member of FTE.BigDfromTN is gaining momentum as a positive member of FTE.
For my prior 06 F150 I asked this question of another forum member that is a retired ford Tranny engineer. Below was his reply...
Don, a fan will help at low speed and stop and go. Your temp on the highway is just fine. 203 isn't anything to worry about. If it doesn't get over 220 you are fine.
Mark
__________________
Mark
Former Ford Automatic Transmission Engineer
Old 11-13-2012, 07:26 AM
I've seen tables like this, but that still doesn't jive with the maintenance schedule Ford publishes. I'm changing mine at 50K regardless.
Old 11-15-2012, 10:08 PM
Thank you everyone for the replies. I appreciate it!
-CN
4r100 temp question cuttn4fun 1999 - 2003 7.3L Power Stroke Diesel 7 03-16-2014 02:10 PM
Engine Oil Temp v Coolant Temp Bigtruc 1999 - 2003 7.3L Power Stroke Diesel 20 12-26-2013 11:24 AM
what is normal oil temp? Rushmore X 1999 - 2003 7.3L Power Stroke Diesel 14 05-22-2013 10:27 PM
transmission temp ronald48 1999 to 2016 Super Duty 6 11-29-2012 08:43 AM
Excessive amount of gauges 86f250XLT-4x4 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 51 10-27-2011 11:57 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
